Thinking about straight pipes
Old Feb 3, 2009 | 07:56 PM
Firedawg1944's Avatar
Firedawg1944
I am thinking about straight piping my truck. Anyone had good results with this?
Old Feb 3, 2009 | 08:34 PM
96sherm's Avatar
96sherm
if there's nothing else done to the truck, its a waste of time and noise. if you are/have a reputable CAI, and tuner, straight pipe is ok, provided you don't go too big with your pipe, and make sure you integrate a "X" pipe or "H" pipe in there to keep the flow more even between the sides. remember that a tune will need to be written to keep the O2 sensors from throwing codes and CEL's...
lots of guys will spout backpressure and legal issues...
Old Feb 3, 2009 | 08:45 PM
Firedawg1944
Ok thanks. I have a friend thats pretty high up in the custom tunning world that is getting me a tuner lined up. I just like the sound. Legal issues are just more waisted thoughts. Thanks for the info though.
Old Feb 3, 2009 | 08:47 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
you do lose backpressure and torque...and yes, the cops can/will write you tickets in certain areas
straight pipes don't gain you anything but noise. You can get better performance results using a catback system
just depends on how much money you want to spend
96sherm's Avatar
96sherm
biggest thing i stress is to match your intake velocity with your exhaust velocity. this done properly with a X pipe will be a good system. you don't "lose" any torque at all. if the intake is matched to the exhaust, nothing will be lost. it may feel like it, but it has actually just changed the torque curve to a higher RPM than stock/catback... Leaving the 4 cats in there and running duals without mufflers wouldn't be a bad thought either...
Old Feb 3, 2009 | 09:01 PM
Svets96's Avatar
Svets96
It would sound great, while attaining the 4 cats as stated above. As for the center mid pipe the x will give you a more raspy sound, vs an H will give you a more true "muscle car " sound. You could also put 2 high flow cats on with a new catback, this will also make it sound awesome. There are many avenues that you can choose. Its hard to choose sometime. lol hope this helps.
Old Feb 4, 2009 | 08:23 AM
Ryan50hrl's Avatar
Ryan50hrl
While you may think that the legal questions are wasted thoughts...keep in mind epa fines for removing cats off a vehicle (or even swapping in high flows with low enough mileage or age) can get you a 25,000 dollar fine......Go ahead and put in straight pipes...but i'd leave the cats....
Old Feb 4, 2009 | 08:48 AM
Firedawg1944
Thanks for all the info. I had always planed on leaving the cats in place. I should have mentioned that. I was going to take out the y pipe where the two come together and start my duals there. I had also planned on putting a x pipe about mid ways back. I think it will sound good. Once again thnks for all your help, and info.
Old Feb 4, 2009 | 09:37 AM
jsoko's Avatar
jsoko
I've heard it on another truck, sounded great stay with 2 1/2" pipe and leave clearance if you decide to install mufflers later
Old Feb 4, 2009 | 06:31 PM
Svets96's Avatar
Svets96
I'm not saying to take the cats off. Just run straight pipes off of the cats meaning you will have no muffler. Keep the converters on. I should have said this in the first place.
Old Feb 4, 2009 | 06:59 PM
slomafarms's Avatar
slomafarms
where can you get a good affordable catback system??
Old Feb 4, 2009 | 09:41 PM
Firedawg1944
Thanks once again for all the info I made an appointment with the exhaust shop for tuesday so I'll let you all know what it turns out like. Thanks once again.
Old Feb 5, 2009 | 07:33 PM
Svets96's Avatar
Svets96
How did the appointment go? What type of combo did you go with? Very Excited right now!lol
Old Feb 5, 2009 | 07:44 PM
nflfreak43's Avatar
nflfreak43
he was talking bout next tuesday. since when he posted this was on Wednesday.
Old Feb 5, 2009 | 07:56 PM
Firedawg1944
Yeah nfl is right. The soonest they could get me in was this coming tuesday. But i will put a sound clip up on you tube and i'll post a link up on here for you all to here it. Thanks once again.
