OBD Code PO125
Old Feb 4, 2010 | 10:54 AM
djusino's Avatar
djusino
I just ordered a termostat yesterday and I'll let you know if that helped. I want to thank all of you for the support. GO NAVY
Old Feb 4, 2010 | 06:20 PM
projectSHO89's Avatar
projectSHO89
Originally Posted by fordtech08
this is out of fords workshop manual, I guess you never bother to get to the bottom of the list
Diagnostic Trouble Code (DTC) P0125 indicates the CHT sensor has not achieved the required temperature level to enter closed loop operating conditions within a specified amount of time after starting engine. This DTC will light the MIL.
Possible causes:
  • Insufficient warm up time.
  • Leaky or stuck open thermostat.
  • Low engine coolant level.
  • Malfunctioning CHT sensor.
No, I specifically read the REST of the relevant section of the WSM in addition to the section you quoted.
Dig deeper. Start by reading the entire diagnostic chain.
Old Feb 4, 2010 | 07:26 PM
fordtech08's Avatar
fordtech08
well I guess you didn't read the first step which just so happened to be my original question.
was it blowing warm before the gauge started working? trying to figure out if it's your t-stat or your temp sender
<TABLE border=1 rules=groups cellSpacing=0 cellPadding=3 width="96%"><TBODY><TR><TD colSpan=2> C1 CHECK THE ENGINE TEMPERATURE</TD></TR></TBODY><TBODY><TR vAlign=top><TD vAlign=top>
</TD><TD vAlign=top>Start the engine and allow the engine to idle for 10 minutes.
</TD></TR><TR vAlign=top><TD vAlign=top>
</TD><TD vAlign=top></TD></TR><TR vAlign=top><TD vAlign=top></TD><TD vAlign=top>Feel the inlet and heater water hoses and the underside of the upper radiator hose.
</TD></TR><TR vAlign=top><TD></TD><TD>
  • Are the upper radiator hose and the heater water hoses cold?
Yes INSTALL a new water thermostat.
No GO to Section 413-01for diagnosis and testing of the engine coolant temperature gauge
</TD></TR></TBODY></TABLE>
griggssteve
2004 - 2008 F150
Jan 10, 2017 07:32 AM
dibzz
Jan 15, 2016 11:46 AM
MANNY RUIZ
Jan 9, 2013 10:36 PM
dhenthorn
Jun 28, 2011 06:07 PM
Heavenword1
Dec 5, 2007 05:23 PM
