ranger vs explorer axle
Old Feb 3, 2009 | 01:04 PM
breakfree's Avatar
breakfree
does anyone know if the 8.8 out of an explorer is the same wheel to wheel width as one in a ranger? thanks.
Old Feb 3, 2009 | 07:08 PM
dadlovesfords's Avatar
dadlovesfords
Here's your info!
The Ford Explorer 8.8-Inch Rear Axles
Old Feb 3, 2009 | 07:11 PM
dadlovesfords
Other post might not work with mods. Here is the basics.
Replacing A Ford Ranger 7.5-Inch Axle With An Explorer 8.8-Inch Axle
Explorer 8.8 Facts:
Has 31-Spline Axle Shafts
Beefier 3.25-Inch Axle Tubes
10-Inch Drums From 1990-1994
1995+ Have Disc Brakes
Rear Ends Are 1.5-Inches Wider Than 7.5-Inch Rear Ends
Needs Shock Mounts Welded On
Needs Spring Perches Welded To Top Of Axle Tube
Most Have Limited-Slip (Traction Lok)
Same 5x4.5 Wheel Bolt Pattern As Ranger
Pre-1990 Ranger Driveshafts Will Not Bolt Directly Up To The Explorer 8.8 (Have Custom Shaft Made Or Get A 1990 Or Newer Shaft)
Old Feb 3, 2009 | 08:05 PM
HappyJack's Avatar
HappyJack
Is the rear pinion in the same place on both? I though the Ranger was off set to one side to clear the gas tank. Maybe I'm thinking about the BII vs the Ranger rear axle.
Old Feb 3, 2009 | 08:09 PM
dadlovesfords
Ranger is the same.Like you said happyjack , your thinking of the Bronc II Rearend that is offset.
Old Feb 3, 2009 | 08:16 PM
HappyJack's Avatar
HappyJack
Pretty sure the BII is centered. The Ranger is offset to clear the side tank and the Explorer may be also as it has a side mounted tank. Just not sure if they were offset the same. I can go out and measure my 94 Explorer tomorrow.
Old Feb 3, 2009 | 08:58 PM
breakfree's Avatar
breakfree
thanks guys, that answers it and then some. im buying the axle for the rear of my jeep(i know, i know, but the price was right...) and id heard the explorer axle was better, i just couldnt find why. cheers.
Old Feb 4, 2009 | 02:33 AM
460's Avatar
460
But in the chart, it says the 7.5 is 56.5", and the 8.8 is 59.75".
Which is correct?
Old Feb 4, 2009 | 10:15 AM
dadlovesfords
That's a good ? 460. I guess I'll do a little more investigating. I'll get back soon.
Old Feb 4, 2009 | 10:28 AM
dadlovesfords
This should explain a little better
Ranger 4.0
1990-1992
Width is same as other pre-93 axles, 28 spline
3.08 (4x2), 3.55, 3.73 and 4.10 (4x4) factory ratios
Either limited slip or open differential
10" drum brakes
Ranger 4.0
B4000
1993+
1994+
Width is same as other 93+ axles (1.5" wider than pre 93), 28 spline
Ratios and differential options as noted above
Ranger FX4
2002+
Width is same as other 93+ axles, 31 spline
4.10's and Torsen limited slip from factory
Explorer
Navajo
1990-1994
Width is 1.5" wider than 93+ Ranger, 3" wider than pre-93, 31 spline
Spring perches must be fabricated and welded on top
Stock spring perches can be used to lower the truck (like a flip kit)
Shock mounts must be fabricated and welded on
Very common to find ltd. Slip, usually 3.73 or 4.10 (4x4) gears
Explorer
Mountaineer
1995-2001
Same as above, also has rear discs
Old Feb 4, 2009 | 06:38 PM
460's Avatar
460
Lot's of good info there, thanks for posting it!
Old Feb 5, 2009 | 09:18 AM
dadlovesfords
Learned at lot before I got rid of My Ranger a while back. I still miss it once in awhile!
Hope the info helps others too!
Larry
bsullivan17
General Automotive Discussion
Aug 11, 2016 08:12 PM
AmazonRanger
Oct 6, 2006 06:10 AM
ranger pat
Sep 12, 2001 10:25 PM
1977 ranger xlt
Aug 14, 2001 07:38 PM
