Ranger Wheels vs Explorer Wheels
Old Oct 4, 2006 | 07:35 PM
AmazonRanger's Avatar
AmazonRanger
Does anybody know for sure if similar year("99-'01) Explorer (OEM) wheels will fit the Ranger (2wd)? Is the offset the same? Will 205 tires fit the Explorer wheel?
TIA
dws
Old Oct 4, 2006 | 08:22 PM
Tiggie's Avatar
Tiggie
The Explorer wheels from the years you mentioned should work fine on a Ranger.
As long as the rim size is the same (i.e. 15 or 16inch), the tires will probably fit. I think most Explorer wheels are 7 inches wide, and I think a 205 tire might be a little skinny, but it will fit (I would recommend a wider tire, however).
Old Oct 5, 2006 | 03:16 PM
rubydist's Avatar
rubydist
Until they went to irs on the Explorers, the wheels were interchangeable. The new Expl w/ irs has more offset (~20) v. the Rangers 12mm. 205 is narrow for a 7" wheel - I'd also recommend a little wider like 225.
Old Oct 6, 2006 | 06:10 AM
Bob Ayers's Avatar
Bob Ayers
I just put some alloy wheels from a 1991 Explorer on my 1999 2WD Ranger.
They worked great!
Check out the pictures in this thread:
https://www.ford-trucks.com/forums/5...-a-ranger.html
eric_engler
Jan 4, 2014 02:38 PM
breakfree
Feb 5, 2009 09:18 AM
JCwarrant
Bronco II
Feb 21, 2006 06:28 AM
qwik88
Dec 23, 2004 04:34 PM
