Punched out cats....
Old Jul 6, 2001 | 07:19 PM
97expy5_4's Avatar
97expy5_4
Everyone on this forum is talking about punched out cats....
I understand that their talking about hollowing out the cats to produce better flow.... BUT will it still pass emissions testing... Will I see or fell any performance improvments from punching out the cats???? I've looked at mine, and this would be no easy task.... Should I cut off the pipe right before and after the cats to allow for easy access???? Now if I do this, wouldn't it be a dead give away at inspection time????
Please help I'm working on a budget... I'm married...!
Old Jul 6, 2001 | 07:56 PM
whomrig's Avatar
whomrig
If you hollow out your cat, it will not pass emissions testing. no way no how. Your vehicle was designed to run with all emissions equipment in place, as long as all equipment is working you should have no problems I would think.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 6, 2001 | 09:29 PM
irishpride's Avatar
irishpride
As an alternative, some race shops can supply you with a switched "bypass" pipe. These are not necessarily "street legal", but allow you to run your cat and muffler or (depending on installation) bypass the cat, muffler, or both. Most often used on "street legal" drag vehicles, e.g. you drive with the bypass disengaged to the track, then switch the cutouts to run straight out.
Here in the Midwest (NE) it's legal, even in the cities, to have these installed, but illegal to use them on the street. Of course, we don't have mandatory emissions checks, either.
Old Jul 7, 2001 | 02:36 PM
StrangeRanger's Avatar
StrangeRanger
If you have a 97, you have OBD-II. It probably won't run worth crap, and may even go into some variant of limp mode if you remove or bypass the cats.
Old Jul 8, 2001 | 07:44 PM
97expy5_4's Avatar
97expy5_4
What is the OBD-II??? Never heard of it before.....
Is this the oxygen sensor or something.... I see some wires coming out of the cats.....
Old Jul 8, 2001 | 09:43 PM
StrangeRanger
On Board Diagnostics II. Began with the 96 model year. Basically an "improved" engine control/diagnostics system which is significantly more modofication resistant than the preceding ODB-I.
See www.obdii.com for more info
Old Jul 9, 2001 | 09:18 AM
deere81's Avatar
deere81
It won't pass emission testing
Old Jul 9, 2001 | 03:28 PM
crazy_goodolboy's Avatar
crazy_goodolboy
