fly wheel ring gear
Old Feb 3, 2009 | 09:12 AM
pintoches's Avatar
pintoches
fly wheel ring gear
I need to change the flywheel ring gear on a 85 ford 300 I6 T 18
I now how to drop the tranny and all that crap.
but how do you change the ring on the fly wheel after its out of the truck?
Old Feb 3, 2009 | 12:28 PM
Lazy K's Avatar
Lazy K
The ring gears are generally "sweated" on so the usual thing is just to buy a new flywheel complete. Hope this helps.
Old Feb 4, 2009 | 02:41 PM
rclarke's Avatar
rclarke
The ring gear can be knocked off with a hammer and punch. The new ring gear is installed by heating it hot enough to expand so it will drop onto the flywheel. I always used a torch to heat the ring gear, keep the torch moving so the ring gear is heated evenly.
Old Feb 4, 2009 | 06:30 PM
wickedinhere's Avatar
wickedinhere
I would think a machine shop could press it on.
Old Feb 4, 2009 | 06:58 PM
FL299's Avatar
FL299
Like rclarke says - works every time !
Old Feb 4, 2009 | 07:11 PM
wickedinhere
Good to know i am changing mine next week. Do you just let it cool slowly
after you get the ring on there?
Old Feb 4, 2009 | 07:16 PM
FL299's Avatar
FL299
Yes just let it cool on it's own as it will cool quickly once it is on the flywheel. Good luck !
Old Feb 4, 2009 | 07:42 PM
wickedinhere
Thanks, i will post how it goes.
Old Feb 5, 2009 | 07:55 AM
FL299's Avatar
FL299
I should also mention that you should look at the inside of your new ring gear for a chamfer that would go toward the shoulder of the flywheel.
Old Feb 5, 2009 | 09:57 AM
wickedinhere
I just knocked my ring gear off it came off easier than i thought it would. I didnt see any chamfer on the ring gear but the new one might have one.
Old Feb 5, 2009 | 10:56 AM
FL299's Avatar
FL299
They do come off quite easily. Some ring gears have a chamfer and some don't - your new one probably won't have a chamfer either. Good luck - you are doing well !
Old Feb 7, 2009 | 12:54 PM
RTM's Avatar
RTM
I like to stick the flywheel in the freezer and then as mentioned heat the ring gear up and install it. It drops right in place on the flywheel and yes it will cool quickly but don't grab it with your bare hands right away.
Most of the time you can just flip the ring around and reinstall it on the flywheel.
Old Feb 15, 2009 | 05:44 PM
wickedinhere
I finally got my flywheel resurfaced and i got my ring gear on today put the flywheel in the freezer and heated the ring gear and it worked great.
Old Feb 15, 2009 | 06:31 PM
FL299's Avatar
FL299
Congratulations ! Glad to hear you were successful ! Now you know how straight forward it is you are perpared to do more should the need arise. Good job !
Old Feb 15, 2009 | 07:49 PM
pintoches's Avatar
pintoches
got my job all most done. ring gear for 30 min in the oven at 500F and it fell right on! i forgot to get the the alignment tool
1976HighBoy
Aug 26, 2011 07:46 PM
sedly
Jan 23, 2011 09:31 PM
TheWingnut
Aug 15, 2009 09:01 PM
cmbroo1
Nov 28, 2007 09:06 PM
