Eagle Wheels?
Old Feb 4, 2009 | 01:07 PM
jdecker88's Avatar
jdecker88
I forgot about his, I will check him up on that I believe he still had them.
Old Feb 4, 2009 | 02:40 PM
superduty4x4's Avatar
superduty4x4
JD, you can also pick up Blue Magic at Walmart- I use the stuff too and really like it.
Old Feb 4, 2009 | 03:29 PM
DCSpecial's Avatar
DCSpecial
Factory lug nuts will not work.
Do not attempt to use them, you need 14mmX2.0 lug nuts with with the tapered seating area.
Old Feb 4, 2009 | 03:43 PM
indebt's Avatar
indebt
Sorry JD , superduty outlaw got em.
Old Feb 4, 2009 | 03:46 PM
fxstbchopper's Avatar
fxstbchopper
I sent you a PM Justin..
Old Feb 4, 2009 | 04:14 PM
jdecker88's Avatar
jdecker88
We'll see what we got when I get down there if they are really scuffed up I might pass or get him down cheaper. It will be a good bit before I could put them on so I will have plenty of time to find the lugs and the center caps. Thanks for the help guys!
Old Feb 4, 2009 | 04:26 PM
DieselCamper01's Avatar
DieselCamper01
Originally Posted by jdecker88
If you want it I can get it and mail it :-p.
Wonder how much shipping would be? Hmmm?
Old Feb 4, 2009 | 04:45 PM
jrf250's Avatar
jrf250
if those rims are alumn. they will polish out pretty easy. If they have slight scraches or scuff marks, You can use some 1500 or 2000 sandpaper and then polish out with some metal polish. I do that all the time where I work at. We even polish out raw alumn. that way. 5" exhaust sounds tempting.
Old Feb 4, 2009 | 04:53 PM
jdecker88's Avatar
jdecker88
5" diesel exhaust thats the exhaust it would run a good bit of your system but you wouldn't have the down pipe and you'd be missing some I don't know where the cats are on a 6.0.
Old Feb 4, 2009 | 05:18 PM
DieselCamper01
I missed that. Good point. I was thinking turbo back. Dang!
Old Feb 5, 2009 | 01:26 PM
sand1's Avatar
sand1
Originally Posted by DCSpecial
285s are fine on a 8" wide wheel.
Those wheels appear to be in need of a serious polishing.
i run 295s on mine and they ride fine
Old Feb 6, 2009 | 09:36 AM
jdecker88's Avatar
jdecker88
I did not get the wheels they were in alot worse shape then the pictures showed they were in the weather for 2 years and had some deep scratches in them the guy said he bought them as mud wheels and they would be perfect for that. Does anything else match our SD lug pattern?
Old Feb 6, 2009 | 01:10 PM
  #28
DCSpecial's Avatar
DCSpecial
99+ SDs are the only trucks that use the 8x170mm bolt pattern.
Old Feb 6, 2009 | 02:06 PM
  #29
jdecker88's Avatar
jdecker88
Thanks Dan, they would make good winter wheels for someone.
