We'll see what we got when I get down there if they are really scuffed up I might pass or get him down cheaper. It will be a good bit before I could put them on so I will have plenty of time to find the lugs and the center caps. Thanks for the help guys!
if those rims are alumn. they will polish out pretty easy. If they have slight scraches or scuff marks, You can use some 1500 or 2000 sandpaper and then polish out with some metal polish. I do that all the time where I work at. We even polish out raw alumn. that way. 5" exhaust sounds tempting.
5" diesel exhaust thats the exhaust it would run a good bit of your system but you wouldn't have the down pipe and you'd be missing some I don't know where the cats are on a 6.0.
I did not get the wheels they were in alot worse shape then the pictures showed they were in the weather for 2 years and had some deep scratches in them the guy said he bought them as mud wheels and they would be perfect for that. Does anything else match our SD lug pattern?
