Hey all,
I am lookin at doing a conversion using a v10 and torqshift auto. i will be making a custom adapter to use a nissan transfer case.
My question is are all torqshift transmissions the same between different engines ie 5.4, 6.8, 6.0D, 7.3D.
And are they the same between 2wd and 4wd apart from the tail-housing?
Thanks
steve
7.3 diesel doesn't have the torqshift. Depending on the model years your talking about the 5.4 and the 6.8 may or may not have the torqshift either. 2005 and up is where the gas burners have the torqshift.
i think the transfer case will be fine, A couple of mates of mine are using them behind big HP motors. One is a supercharged stroked LS2, the other a tuned 6.6L Duramax and allison 6 speed.
I think it will be fine
