Ouside Temp Reading Off
Old Feb 1, 2009 | 01:51 PM
bomber468's Avatar
bomber468
I have a 2004 FX4 with the 5.4L Triton. I've noticed that on the instrument cluster the outside temp reading is several degrees off. Does anyone know if there is a calibration procedure or is it just something you replace when it starts to go?
Old Feb 1, 2009 | 04:28 PM
N3mo's Avatar
N3mo
don't get fooled by the fact that it picks up het from the engine when you park. Once you get rolling , it drops to normal.. I don't know of any calibration.
Old Feb 1, 2009 | 04:58 PM
svt2205's Avatar
svt2205
Several degrees off isn't unusual. If I remember correctly Ford allows plus or minus 5 before they consider them bad. You could replace the sensor, but you might end up with one that's worse.
Old Feb 1, 2009 | 05:32 PM
slomafarms's Avatar
slomafarms
i got mine replaced at the dealer...$40 later it works like new
Old Feb 4, 2009 | 06:14 PM
bomber468's Avatar
bomber468
Thanks for the ideas. I noticed that it does it when it first starts and continues so engine heat isn't an issue. I can order the part from directfordparts.com but don't want to waste money is it can be calibrated or something first.
