driveshaft question???? please help!!!!
Old Jan 31, 2009 | 11:11 AM
MICHAELHARPER11's Avatar
MICHAELHARPER11
i have a 1992 ford f150 4x4 reg cab flareside xlt with 351w and e40d automatic. i am installing a 6" suspension lift and 3" body lift. my question is this, will the driveshafts have to be legthened? and if so what does the overall legth need to be. i'm buying my suspension monday so any quick response would be greatly appreciated. thanks. michael.
Old Jan 31, 2009 | 11:48 AM
armycain's Avatar
armycain
what kind of lift are you buying? Also you will need to do something with your driveshaft but might not need lenghting . Some of the Lift company's have transfer case drops that allow use of stock driveshafts and if they don't they should be able to tell you exactly how much you'd need to lenghten.
Old Jan 31, 2009 | 05:00 PM
Collins150's Avatar
Collins150
No driveshaft or transmission mods needed. Sometimes they give you a angled block in the rear to correct pinion angle but that shouldnt be needed for a 6 inch lift.
Old Jan 31, 2009 | 09:18 PM
MICHAELHARPER11
ok, the lift is from rough country. it's a 6" suspension Front coil springs, radius arm drop brackets, I-beam drop brackets, power steering pitman arm, 4 Nitro 9000 series shocks, u-bolts, and 3" rear blocks w/ add-a-leafs. also dual steering stabilizers and extended front and rear brake lines. and the body lift is also a rough country 3" body lift.
david00f150
1966 - 1977 Early Broncos
Aug 3, 2009 05:06 PM
6CylBill
Offroad & 4x4
May 4, 2009 08:20 PM
chickenfry123
Offroad & 4x4
25
Dec 8, 2008 09:11 PM
johndo
Apr 25, 2004 07:40 PM
AbadDriver
1978 - 1996 Big Bronco
18
Aug 22, 2003 03:24 PM
