64 ford 4x4
Old Jan 31, 2009 | 10:14 AM
brian502's Avatar
brian502
Smile 64 ford 4x4
need some help im trying to find some info on power steering.ihave 64 4x4with a 390 engine i want to install power steering. can this be done with over the counter parts or used parts. thanx brian
Old Jan 31, 2009 | 10:18 PM
garbz2's Avatar
garbz2
64 uses the Gemmer Box in a 4x4 application.
There is no bolt on ore easy application as the Gemmer like the ford box is integral shaft type, meaning the box and shaft are one piece from the box to the steering wheel.
Successful swaps have been made with the use of a mid eighties Toyota 4x4 box partial Pittman arm and modifications to the steering shaft and column.
Each requires fabrication skills and the Pittman needs welding skill to do.
Garbz
Old Feb 7, 2009 | 05:03 PM
napass2004's Avatar
napass2004
im in the same boat i also have a 64 4x4 and ive been told a newer ford 2wd box will work if you reverse the arm benchworks.com has a kit pretty pricey though. Even when you solve the box problem u have to figure out what to do about a steering column. Keep me updated on what you decide to do and how you do it.
Kyle
minkbigbird
Aug 15, 2013 03:26 PM
BJohnson61
Aug 14, 2011 11:40 AM
dusted74
May 9, 2004 04:17 PM
ford 8 1/2" mods
Apr 14, 2004 06:58 PM
Comer14
Mar 6, 2003 07:40 PM
