Cold water temp.
Old Aug 12, 2013 | 07:17 PM
minkbigbird's Avatar
minkbigbird
Cold water temp.
Hi all. I am having trouble getting the engine to warm up in my 64. 292 f600. Have had a complete engine rebuild and brand new 4 core rebuilt original radiator after a drive the temp gauge hardly moves and the radiator is only slightly warm.
Its worse in winter and a little better in summer I was thinking of putting a cover in front of the radiator? is it practical to use a shutter style cover as used on some of the bigger trucks? any thoughts welcomed or photos. thanks Brian.
Old Aug 12, 2013 | 09:37 PM
bertha66's Avatar
bertha66
Do you have a thermostat in the engine? And yes, in the past cardboard was used a lot to heat up the old trucks.
Old Aug 15, 2013 | 06:11 AM
minkbigbird
Cold water temp
HI. yes I have installed a thermostat to the correct setting, you will find this hard to believe but I have have spent over 12K on the engine alone its a show pony may be it needs 7 ton up a 4 mile steep hill and see what happens.
Old Aug 15, 2013 | 09:31 AM
bertha66's Avatar
bertha66
What temp of thermostat do you use?
Old Aug 15, 2013 | 10:36 AM
daveengelson's Avatar
daveengelson
It would seem to me that if you installed a thermostat and you can detect when it opens by observing the water level and flow thru the radiator then I would question the accuracy of the gauge and/or sending unit???
Old Aug 15, 2013 | 03:09 PM
The Masked Rider's Avatar
The Masked Rider
The one 65' I drive all the time, has a 352 and the optional heavy duty radiator. It has an electric fan. Even in 3 digit temps, that fan will only come on if I'm setting in traffic. And only for a short time. There is so much air space around the motor in these trucks and these blocks and heads have large water passages. I run a 180* thermostat. A friend of mine up north uses card board in the winter. Years ago, I used cardboard in my fat fendered Studebaker pick up. And it even had the 'factory' 292 Hemi in it. See if anyone picks up on that....
Old Aug 15, 2013 | 03:26 PM
charliemccraney's Avatar
charliemccraney
Use an infrared thermometer on the thermostat housing. I bet you'll find it's right about where it needs to be.
If your sender is in the factory location, and everything is accurate, it will indicate about 20 degrees less than the temp at the thermostat. This is because coolant still needs to move to the front of the engine and pass over 3 more combustion chambers and absorb some more heat.
Randy Nix
13
May 19, 2019 05:15 PM
Krazymaan
Sep 26, 2009 08:07 PM
Broncobudy
1978 - 1996 Big Bronco
18
Apr 5, 2008 10:30 PM
beaterbronco
Feb 28, 2007 12:43 AM
mustang67
1983 - 2012 Ranger & B-Series
Feb 18, 2003 10:08 AM
