1987 F-350 fuel pump question
Hope someone on here can help. Anyway I have '87 F-350 DRW with 460 carb. and dual tanks. Did Ford build this particular year with the fuel pumps in the tanks only ? I've checked along the frame rail from the fuel selector valve to the carb and have not seen another fuel pump. I'm only asking because most parts books refer to the possibility of one in tank pump and one along frame rail. My rear tank pump needs replacing and I'm going to replace the whole assembly with the sending unit . Thanks
The intank fuel pumps are low pressure pumps for the carb. The frame mounted pump is a high pressure pump to boost the pressure to 40 psi for the fuel injected engines. My '88 has the intank pumps as well as the frame rail pump for the fuel injection.
fordafire
Jul 29, 2012 05:46 PM
flatheadjohn
Dec 2, 2009 01:15 PM
LS1 Powered
Jun 22, 2009 07:55 PM
spikedog
Aug 28, 2006 10:02 AM
