Fuel problems
Old Jul 26, 2012 | 08:24 PM
fordafire's Avatar
fordafire
Fuel problems
I have an 84 F-250 with a 460 and dual tanks. Someone worked on it before me and it has a fuel pump between the saddle tank and the frame rail. I have been told that this is an add on fuel pump. I dropped the saddle tank and replaced the pump, the line from the saddle tank ran through the frame rail pump. I turned the key on and could hear a ticking which I assume was the fuel pump, I got fuel at the carb. It ran for a while then I tried to drive it but it stalled and I had to tow it back with the ranch tractor. I then bypassed the frame pump and the fuel tank selector valve on the frame rail and now I cant get fuel to the carb.
I'm stumped does anyone have any diagrams as to the fuel lines, pumps and selector valve? I do want to use both tanks and know I need the fuel tank selector valve on the frame rail but I do not know what lines go where and may need to replace the frame mounted fuel tank selector valve, I do not know if its good or not. I dont mind re doing all the lines, pumps and the valve. Its just since someone got to it before me a lot of stuff was disconnected so I dont know what goes where. I replaced the fuel relay already and my hanes manual is dang near worthless.
Thanks Rich
Old Jul 26, 2012 | 08:53 PM
bruno2's Avatar
bruno2
Rich I bet Chris Tubutis can get those diagrams for you. If he doesnt chime in give him a PM. He is the mod here he goes by ctubutis.
Old Jul 26, 2012 | 10:18 PM
ctubutis's Avatar
ctubutis
I have a 1986 fuel system wiring diagram, I *think* it applies to 1984 but I wouldn't bet my life on it.
I will have to find a place to upload it (I'm thinking Google Docs or some such) as my 'net connection is too slow for FTE's software, it times out before the entire thing gets uploaded. It's 20MB in size.
IIRC those 460 fuel tank senders with the attached pumps are pretty difficult to find and, when found, cost a couple hundred bucks. This is probably why you have the ******-rigged system you have, a PO was too cheap to do it right.
The factory units are expensive but they last FAR longer than the aftermarket things.
I'll try to dedicate some time to this tomorrow.
Old Jul 26, 2012 | 11:49 PM
bruno2's Avatar
bruno2
Hey Chris, I am a ****** and I found that to be offensive.
Old Jul 26, 2012 | 11:57 PM
ctubutis's Avatar
ctubutis
Hey, Bruno...
Old Jul 27, 2012 | 01:06 AM
fordafire's Avatar
fordafire
Thanks to all who replied. I am mostly looking for the hose and associated component diagrams. So does this thing have a stock frame rail mounted pump as well as the 2 in the tanks and the dual frame mounted switch that has the 6 ports? The frame mounted pump only has 1 in and 1 out nipple on it for hoses.
I am anxious to get this thing running as I will be able to use it and the car hauler that goes with it when I need it. It will come in handy for moving big pieces of my crew cab to paint and powder coat plus I need a 94-98 2 wd dodge with a cummins and 5 speed man for the crew cab. I also need the back half of a 78 79 Bronco and a section with the small rear window of a supercab to fill the gap. This truck and trailer will allow me to buy stuff that aint running for projects. Here is what I am building [IMG]<a href="http://s1086.photobucket.com/albums/j454/offduty60/?action=view&amp;current=86.jpg" target="_blank"><img src="http://i1086.photobucket.com/albums/j454/offduty60/86.jpg" border="0" alt="Photobucket"></a>[/IMG]
Anyone can fax me at (805) 649-1689 the phone is for fax only and should only ring once
Rich
Old Jul 27, 2012 | 10:26 AM
ctubutis's Avatar
ctubutis
That's a Centurion conversion, Ford never built or sold anything like that.
Seems Google Drive requires using a special app to upload things and this app is available for Linux, I'll find some other sharing place for the wiring stuff. Maybe later tonight or tomorrow.
As for the plumbing, I think this is the best the parts catalog can offer....
http://www.flickr.com/photos/ctubutis/7656667308/http://www.flickr.com/photos/ctubutis/7656667308/ by http://www.flickr.com/people/ctubutis/, on Flickr
http://www.flickr.com/photos/ctubutis/7656667934/http://www.flickr.com/photos/ctubutis/7656667934/ by http://www.flickr.com/people/ctubutis/, on Flickr
http://www.flickr.com/photos/ctubutis/7656667636/http://www.flickr.com/photos/ctubutis/7656667636/ by http://www.flickr.com/people/ctubutis/, on Flickr
Old Jul 28, 2012 | 07:53 AM
ctubutis's Avatar
ctubutis
OK, I am not gonna upload this file because it's already on the 'net, just not here on FTE. It is 8 pages from the 1986 EVTM and shows the fuel pump stuff.
It's on Bill Vose's (85lebaront2's) personal web site and can be gotten from there:
Old School Hot Rodder » Downloads
To be honest, I;, not sure how much it will help, though. According to the parts catalog, a stock 1984 truck had mechanical fuel pumps and not electric ones in the tanks. The sending units ID'd with 9275 tell me this.
But this is a Centurion conversion truck, and I have no idea what they did....
Old Jul 29, 2012 | 05:46 PM
fordafire's Avatar
fordafire
The truck I am working on is an 84 f-250 that is a single cab 2 wd with dual tanks and a 460. The truck in the pic is someones creation I would like to duplicate with my 74 crew. I dont believe Centurion did anything with the dentsides.
LipRipper3006
Dec 30, 2017 05:52 PM
NicksF250
Jan 28, 2016 05:37 AM
sitdog84
May 28, 2014 01:44 PM
skaven
Jun 18, 2010 04:01 PM
stevegooch
May 30, 2004 05:27 PM
