6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Engine Code Please help
Old Jan 30, 2009 | 03:09 PM
seabee40's Avatar
seabee40
My wife came back from the store today and the check engine light was on it is showing a code of p0196 can anyone tell me what that is?
Thanks Jim
Old Jan 30, 2009 | 03:48 PM
Larry NCKS's Avatar
Larry NCKS
Thanks Jim
According to my source, P0196 is an engine oil temperature sensor circuit failure of some kind. My source is sketchy so not sure of more details.
Old Jan 30, 2009 | 06:05 PM
PowerStrokeHD's Avatar
PowerStrokeHD
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
Description...
Indicates the value from the engine oil temperature (EOT) sensor is not within the powertrain control module (PCM) predicted engine oil temperature range, based on other PCM inputs.
Possible Causes...
Engine not at operating temperature
EOT circuit concern
EOT sensor
Cooling system problem or stuck thermostat
Diagnostic Aids...
The EOT rationality test looks for the EOT sensor value to be within a calibrated parameter of the PCM predicted engine oil temperature. Make sure the EOT sensor reading is similar to engine temperature. If the EOT reading greatly differs from engine temperature, check the EOT circuitry for correct operation.
Old Feb 3, 2009 | 09:11 PM
marshall99f150's Avatar
marshall99f150
The latest update from the ford dealer is supposed to be a fix for this, I had this code today at work as a matter of fact. Reprogrammed the ecu and now customer said the light stayed off.
26tudor
WTB - Parts & other
Mar 20, 2015 06:00 AM
hammer65
24
Aug 7, 2014 04:40 PM
hammer65
2009 - 2014 F150
Nov 12, 2013 11:17 AM
jrsbronco
1978 - 1996 Big Bronco
Mar 4, 2001 03:07 PM
