Modular V10 (6.8l)
Engine ping V-10
Old Jan 18, 2010 | 07:15 PM
Johnny Langton's Avatar
Johnny Langton
Originally Posted by Tim's2000Truck
Do you know what that might cost?
If it is indeed the tensioner,those are only $49/each. You'll need a LH and RH tensioner-they are different. Changing those requires removal of the cam covers,pullies,fan,damper,PS pump has to drop loose,and the timing cover comes off. Then you'll need to remove that bad tensioner. While you're in there-I'd recommend changing the timing chain guides. They're nylon,and do wear. The chains themselves are probably still perfect-I've only seen a couple over the years that have actually needed replacement. Labor is gonna be the thing-this would take me 5-6 hours total(if the fan comes off easily),but a shop is gonna hit you for book rate-which very well could be much longer.
JL
j43217
1997 - 2003 F150
Oct 11, 2019 01:49 PM
Jimmy Pet
Modular V10 (6.8l)
127
Aug 4, 2019 01:21 PM
reamer
15
Jun 2, 2016 07:40 AM
OpenTrackRacer
Modular V10 (6.8l)
Aug 25, 2015 12:40 AM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
