Door locks don't work
Old Jan 30, 2009 | 09:46 AM
sailorjohn's Avatar
sailorjohn
I recently replaced all the doors on lmy '99 E-350 cargo van with doors from a '92 E-150 Conversion van. The power windows work the power mirrors kind of work but the power locks do not work at all. I do have power going into the switch on the drivers door (didn't check the passangers side). Also I didn't hook up the wiring harness for the side or rear doors. What could my problem be?
Old Feb 1, 2009 | 01:04 PM
MADVAN's Avatar
MADVAN
You have to install all of the lock switches.
The switch itself is part of the circuit.
Bill
Old Feb 2, 2009 | 08:12 AM
pfogle's Avatar
pfogle
It could also be that the '92 door lock actuators are froze up. What was wrong with the '99 doors that you replaced them?
Old Mar 16, 2009 | 12:23 PM
sailorjohn's Avatar
sailorjohn
The '99 doors were 100% manual.
Old Mar 16, 2009 | 09:40 PM
pfogle's Avatar
pfogle
Ok. I'd pull one of the actuators out and bench test it. Get a battery (a 9 volt alkaline is powerful enough) and test them. Also make sure that you've got power at ALL switches. If you've only got power to the drivers door they won't work at all.
Old Mar 17, 2009 | 01:39 PM
rclarke's Avatar
rclarke
The grounds go through the switches also.
crankbait321
Electrical Systems/Wiring
Feb 20, 2022 08:13 PM
jamnjm
Oct 10, 2016 01:34 PM
maagk
Jun 7, 2016 07:17 AM
jdhill95
21
Apr 30, 2016 02:02 PM
roger48624
Feb 11, 2013 04:45 AM
