lol..i got the same style running board..they just dont have the inserts and lights on them.i havent found the right LED insserts yet...but they are gray..
I found some on ebay about a year ago. Came out of Texas and shipping was as much as the boards. The diamond plate was a little chewed up so had some new ones made and powder coated clear, then had the tan plastic rhino lined black. I replaced the end lights with leds and I'm very pleased. Wiring is pretty easy cause all you need is a ground and power wire. I just tapped power from the dome light in the cab.
I think there's some pics in my gallery of them. Maybe in the 05 conversion one.
The only bad thing about the rhino (or any liner) is that it doesn't adhere well to the plastic and if it tears, you can virtually peal the rest right up. I'm planning on stripping mine this spring and painting them with a black textured bumper primer. That way it'll be easy to touch up if needbe, and I'll have the same look as the liner.
The nice thing is that the KR boards are about 6" longer than the stock SD ones. Brackets are all the same, but they go almost to the end of the cab covering up almost all the the pinch weld.
