Truck Not Starting
Old Jan 29, 2009 | 09:42 PM
03_PSD's Avatar
03_PSD
Truck Not Starting
ok guys, my truck is not starting. Its cranking fine just not starting. I tried taking my ts chip out and no change. still not starting. any help would be greatly appresiated. hopefully its somthing simple, hopefully.
Old Jan 29, 2009 | 09:43 PM
Pocket's Avatar
Pocket
CPS or high oil pressure would be the first things I would check.
Old Jan 29, 2009 | 09:45 PM
megawatt00's Avatar
megawatt00
Check your battery voltagewhen cranking. Don't for get that your IDM needs to see 10.5V to start.
Old Jan 29, 2009 | 09:49 PM
03_PSD's Avatar
03_PSD
How would you check your High Oil Pressure?
Old Jan 29, 2009 | 09:52 PM
Pocket's Avatar
Pocket
You would need a scan tool that can show ICP, voltage, and duty cycle.
Old Jan 29, 2009 | 09:58 PM
05chop's Avatar
05chop
Do the 03 have a fuel heater? If they do then it will show up in the fuse holder.
Old Jan 29, 2009 | 09:59 PM
03_PSD's Avatar
03_PSD
crapola! My truck was running fine the it quit.
Old Jan 29, 2009 | 10:07 PM
03_PSD's Avatar
03_PSD
hopefully these codes will help:
1280
0603
Old Jan 29, 2009 | 10:13 PM
Pocket's Avatar
Pocket
I would start with that P1280 code (ICP circuit low).
Try this, unplug the electrical connector on the ICP sensor. Then crank the truck and see if it starts.
Old Jan 29, 2009 | 10:53 PM
03_PSD's Avatar
03_PSD
I just tried unpluging the the ICP and nodda, I'm at a loss, hopefully tomorrow will be a better day.
Old Jan 30, 2009 | 06:27 AM
F350-6's Avatar
F350-6
Glenn, if you're still having problems, try to find RubberDuck in the OBS section. He's in Austin. Maybe he could give you a hand.
Does your WTS light come on? All dash lights work normally? Make sure you didn't run the HPOP reservoir low by cranking too much.
Old Jan 30, 2009 | 07:10 AM
Pocket's Avatar
Pocket
That narrows it down so that it's not the ICP sensor. Next step would be the IPR, and that's where the scan tool is handy to track oil pressures during cranking.
Old Jan 30, 2009 | 09:12 AM
03_PSD's Avatar
03_PSD
I'm about to go outside and look at the truck again. I don't have a scanner that can read pressures or anything like that. Last night was so strange, the truck was running fine then had an odd sound when it was idleing, and seemed like it had a loss of power. Let the truck sit for a while and went out to start it and it would crank and crank but not start. Tried to start it once again and it fired up, but still had an odd idle so I shut it off. Tried to start it again and it never started. I've checked the oil, I can hear the fuel pump running. All the gauges seem to work as the should. Hopefully I'll have better luck this morning. I'll report back shortly, thanks for the help guys.
Old Jan 30, 2009 | 10:21 AM
03_PSD's Avatar
03_PSD
nothing still. Any thoughts about replacing the CPS, ICP or the IPR
Old Jan 30, 2009 | 10:25 AM
Pocket's Avatar
Pocket
Well, one thing to help narrow it down. Using your code reader, clear all codes. Next, make sure your batteries are charged up. Now, crank the truck for a minimum of 10 seconds solid. Hook your scanner back up and see what new codes pop up. That's one way to help narrow things down a bit.
The reason for this test is that certain codes require a time frame before triggering. For instance, the infamous P1211 code requires 8 full seconds of a low or high oil pressure condition seen before any code is triggered. CPS codes also in some cases require a few seconds before the problem is "detected" by the PCM and a code is triggered.
