That's a BUCK TAG, the codes contained on it were used by assembly line workers so they would install the correct parts to match what was ordered.
Buck tags usually cannot be decoded. I cannot make heads nor tails of it, and I've decoded over 600 VIN's here on FTE.
All the info (AXLE, TRANS, COLOR and etc. codes) on your truck are located on the Certification Label found on the B Pillar (door post).
This info can be decoded by myself, or other members here on FTE.
O GREAT GOD OF NUMBERS could you PLEASE decode this for me Ive got a bad feeling its not the 302 with a aod in it so here is the numbers 1FTJE34H7MHA66849
That Vin doesn't match up with any of my books.Could you tell us what the truck is?And possibly recheck the vin?The E34 doesn't match up.It looks like you have a 91 F350,is that correct?It also looks like you have a 351.As for type of trans,the VIN number does not tell you the type of trans.That can be found on the B pillar sticker,which is on the driver's side of the cab.
quote=fordtruckman80;7078617]That Vin doesn't match up with any of my books.Could you tell us what the truck is?And possibly recheck the vin?The E34 doesn't match up.It looks like you have a 91 F350,is that correct?It also looks like you have a 351.As for type of trans,the VIN number does not tell you the type of trans.That can be found on the B pillar sticker,which is on the driver's side of the cab.[/quote]
it is a 91 van no making on van outside as to what E? heres the number again 1FTJE34H7MMHA66849
1FTJE34H7MMHA66849 that is the number on the paper work and if it is a e 350 5.8 what was the most iky trans in it and is this going to shoot down my plug and play in my 85 f150 5.o aod what will I need to make it happen thanks and email me at bfbiker@hotmail.com Ive highjacked this thread to long thanks Phil
Ok I feel petty dumb bout now I usely ck vin numbers whit paper wprk and guess what I didnt this time Turns out paper work doesnt match vin on the van its for a E 350 and I have a E 150hope I can track down the guy who has my paper work now
Also I know it is a 5.0 what I need to know is it a aod trans door jame trans code isT
