Expensive fuel pump!
Old Jan 29, 2009 | 06:25 PM
dadsgreenpsd's Avatar
dadsgreenpsd
So, since I found brass shavings in my fuel bowl, I probably need a pump. This one isn't noisy yet, but I don't want to be left on the side of the road halfway to GA. But I didn't think it would be $250!!! Anyone know of a more economically feasible place to get one?
Thanks!
Old Jan 29, 2009 | 09:11 PM
F350-6's Avatar
F350-6
Where did you get that price quote from? I got one about a year ago from NAPA for $150. Their website shows $198 now.
Old Jan 29, 2009 | 09:14 PM
triskit16's Avatar
triskit16
152 at autozone for my 2000...dont know if theres a difference in the 2000 and 2001 though.
Nope, doesnt look like any difference...
Old Jan 29, 2009 | 09:17 PM
Pocket's Avatar
Pocket
If you've done the pre-pump mods on your truck, then a Walbro is a direct bolt in. Those can be had for just over $100, and flow more than the stock fuel pump.
You can search Ebay for the Walbro GSL392, or you can pick one up from Arizona TPI.
Here's a thread I posted when I installed it: https://www.ford-trucks.com/forums/7...ump-is-in.html
I can't find the other thread with the pictures for install. Someone might have it handy.
Old Jan 29, 2009 | 09:20 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I've heard good things about the Walbro. That is what I will be getting when the time comes.
Old Jan 30, 2009 | 12:24 AM
orng1's Avatar
orng1
Pre-pump? What needs to be done first in order to run a Walbro? I may need one later and I think I'd like to put in a Walbro pump. It's a nice upgrade at less cost than a stock replacement.
Old Jan 30, 2009 | 06:40 AM
Izzy351's Avatar
Izzy351
The Hutch pre-pump mod needs done. It's removing the mixing chamber and extending the return line, and replacing the leaky quick-connect hard fuel line with rubber fuel line & double clamps. Also need a pre-pump filter since the mixing chamber had a screen in it.
The reason is that the Walbro has a nipple for rubber fuel line that you don't have on the stock system.
Old Jan 30, 2009 | 07:02 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
If you want to do stock check with the FTE parts guy, he will give you a GREAT price!!
Old Jan 30, 2009 | 07:38 AM
dadsgreenpsd
I did check his site, it was a bit higher..... I am intrigued by the walbro, if it has better flow and pressure. The bundy fitting is what I am looking for on the front, correct?
Old Jan 30, 2009 | 07:57 AM
Pocket's Avatar
Pocket
If you get the install kit that goes with the pump, then the outlet is a direct bolt on to the stock fuel line. The inlet is not, which is why it's best to have done the pre-pump mods where you remove the quick disconnect fittings between the tank and pump. Once you have a rubber fuel line in place, then the fittings that come with the pump will connect right up to that fuel line.
Old Jan 30, 2009 | 08:23 AM
dadsgreenpsd
Yup, done all the pre-pump stuff. I found several different install kits, however. I am probably, as usual, over analyzing everything. Most of the kits on fleabay show barbed fittings on both ends, and the bundy fitting found HERE looks like the ford QC on the outlet of my stock pump.
Thanks pocket, for the pump info.
Old Jan 30, 2009 | 08:39 AM
big poppa's Avatar
big poppa
Not to get off base or hi-jack but thats one of the warning signs of a pump failure is like a dust particle metalic shavings in the fuel bowl????
Old Jan 30, 2009 | 09:54 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
That's what I was going to suggest, the Walbro worked wonders for my truck. It's way less expensive that the stock pump and will last way longer. A few other fuel mods and my pump will prove it's worth.
Old Jan 30, 2009 | 12:01 PM
aklim's Avatar
aklim
This is interesting but why did you choose a pump that isn't diesel rated? Is there a difference and what are the consequences of that choice?
Old Jan 30, 2009 | 12:07 PM
Pocket's Avatar
Pocket
It's true that they don't warranty this pump for diesel applications. The thing is, this pump has been used for years by diesel enthusiasts, and has really proven itself to be a good replacement. That's why I went with it. Cummins guys have been using it too. Mid-Atlantic Diesel has been selling them for a while. So my decision was mainly based off other's experience and reviews. So far, I've been very happy.
