95 350 overheating problems
Old Jan 29, 2009 | 06:16 PM
raceman308's Avatar
raceman308
I have a 1995 ford f350 with a 460. My temperature gauge would fluctuate from hot to normal. So I changed the thermostat, the water pump and the radiator. The problem stayed the same. Than I changed the temperature gauge from my race car to the truck to see what the temp would be. It runs from 210 to 280 and boils over then cools down then gets hot again.
Any advise??
Please help
Old Jan 29, 2009 | 07:33 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
How are your hoses? You could be collapsing the bottom hose and pinching off coolant flow.
Old Jan 29, 2009 | 07:55 PM
raceman308's Avatar
raceman308
Thanks.....tried that already.
Rolled coat hanger inside all the hoses.
Anything else?
Old Jan 29, 2009 | 07:57 PM
daveshomeservice's Avatar
daveshomeservice
cooling fan clutch??
Old Jan 29, 2009 | 07:58 PM
raceman308's Avatar
raceman308
Changed it.....
OEM from Ford
Old Jan 29, 2009 | 08:08 PM
flamebuster's Avatar
flamebuster
maybe your not getting all the air out of the water jackets in the engine. ran into that on a foriegn car had to losen the heater hose to bleed it. took in a lot more water heard that is common now in newer model vehicles
Old Jan 29, 2009 | 08:10 PM
raceman308's Avatar
raceman308
will try that out flamebuster.....thanks
Old Jun 18, 2011 | 08:28 PM
sreichel1's Avatar
sreichel1
overheating
Sometimes the insides of the hoses collapse only when it is hot and running. Otherwise they seem fine.
Old Jun 19, 2011 | 09:12 AM
deeznuts822's Avatar
deeznuts822
You can also have a defective thermostat,even if it is new.
Old Jun 19, 2011 | 10:45 AM
mdula's Avatar
mdula
That hapened to me. New thermostat, had issues getting to temp. Decided to check it and it was stuck open. When you get a thermostat pay for the higher dollar ones.
Old Jun 20, 2011 | 03:34 PM
redmondjp's Avatar
redmondjp
How about the A/C condenser in front of the radiator - is it possibly blocking airflow (as in chock-full of dead insects on the front side)?
Another possibility is retarded ignition timing and/or a lean air-fuel mixture - these can cause engine overheating as well.
You might try adding some water-wetter to your coolant (they have it at most GOOD auto parts stores) - it increases the transfer of heat from the engine block to the coolant. At this point it can't hurt anything.
I remember fighting this same issue with my dad's 1977 Lincoln Town Car with a 460. It ran too hot no matter what we did with it (dumped a lot of $$ into the same stuff that you already have, with no real improvements), and in the end we just lived with it (it was a third car that only saw occasional vacation-trip use).
bowhunter96
Sep 15, 2021 07:05 AM
abe
Feb 17, 2016 03:02 PM
shore
1997 - 2003 F150
Feb 22, 2015 01:20 PM
Island Time
Aug 29, 2014 09:13 PM
paker
1997 - 2003 F150
Oct 10, 2011 08:15 PM
