Front end riding high! Help!!
Old Jan 29, 2009 | 05:28 PM
JT250's Avatar
JT250
Bought my truck last year. I was told it has a Pro Comp leveling kit in front. I tow a trailer 90% of the time so the back end is considerably lower. However when I dont have the trailer hooked up the front is still about an inch higher. I know on some trucks you can adjust the torsion keys, but as far as I can tell our trucks dont have those. So can you get shorter links that go the the torsion bar or is there another way to let the front down a little bit??
Old Jan 29, 2009 | 05:35 PM
RussB's Avatar
RussB
Its more than likely your rear springs are beginning to sag ! There isn't much you can do with the front..... but If I were you I would check your rear spring to make sure you don't have a broken leaf ! I broke both of mine last year ! Pics are in my Gallery ! take a look ! You may have to add a leaf if your are always hauling a heavy trailer !
Old Jan 29, 2009 | 05:44 PM
JT250's Avatar
JT250
I had to do that to my old ranger, but I didnt figure I would have to with this big of a truck. The trailer probably only weighs 3000 full and wet. I would think it would be able to handle that without sagging. I will check the springs but I dont think anything is broken. I have thought about air bags, but dont want to spend money on that.
Old Jan 29, 2009 | 05:55 PM
RussB's Avatar
RussB
If you tow that amount of weight lots... You will slowly sag the rear end..... Lowering the front isn't going to do much for ya I'm afraid... It doesn't fix the problem.. you're covering it up though !
Its your rear springs IMO !
Old Jan 29, 2009 | 06:00 PM
triskit16's Avatar
triskit16
New leaf springs...add a leaf....rear air bags....
I have bags on my front because front was sagging...i love em.
Adjustable and help out a lot quite a bit!
Old Jan 29, 2009 | 06:07 PM
big poppa's Avatar
big poppa
If the springs arn't bad or broken, why not throw some F-350 blocks on the back, don't know how much you'll gain but that might level it out for you, somebody will chime in that went this route and welcome to FTE.
Old Jan 29, 2009 | 06:19 PM
triskit16's Avatar
triskit16
True....Im going by his ID and not his profile since the profile says F150!
350 blocks will def be the cheapest fix but I dont know how long they will work until the sag catches back up with him...if it does.
Old Jan 29, 2009 | 06:28 PM
big poppa's Avatar
big poppa
Not to bust your chops , but where in there does it say F-150, i looked earlier just to make sure because of no sig?? Just wondering if i,m missing something with all these changes..
Old Jan 29, 2009 | 06:39 PM
triskit16's Avatar
triskit16
About JT250
Location
OKC, OK
2 Letter State/Province (use "--" for outside USA/
ok
Country
usa
Make
Ford
Model
F-150
Year
2003
Current Mileage
75,000 - 99,999
Go to profile....click on about me...
Old Jan 29, 2009 | 06:43 PM
big poppa's Avatar
big poppa
About JT250
Location
OKC, OK
ok
Country
usa
Make
Ford
Model
F-150
Year
2003
Current Mileage
75,000 - 99,999
A HAA, learn something everyday, thanks
Old Jan 29, 2009 | 07:01 PM
triskit16's Avatar
triskit16
No prob! Took me a few minutes to figure out where they were all hiding as well!
Old Jan 29, 2009 | 07:28 PM
zx250's Avatar
zx250
Of the next Riffraff East
... I have thought about air bags, but dont want to spend money on that.
Worth every penny in my opinion. Only wish I had done it years earlier.
Old Jan 29, 2009 | 07:33 PM
bdrummonds's Avatar
bdrummonds
The problem you are having is that the previous owner installed a leveling kit that was mismatched to your truck. The front was overcompensted for and now you have a drag azz truck. Your best solution is to install a set of 4" superlift blocks in the rear (standard F350 blocks are 3 5/8").
Old Jan 29, 2009 | 07:37 PM
F350-6's Avatar
F350-6
I'll agree with the airbags if you tow alot. To me the trucks with a leveling kit always look like they ride nose high
Old Jan 29, 2009 | 07:45 PM
justblowin'smoke's Avatar
justblowin'smoke
mine did until i put the air bags in
