Front end riding high! Help!!
Old Jan 29, 2009 | 07:54 PM
bdrummonds's Avatar
bdrummonds
Originally Posted by F350-6
I'll agree with the airbags if you tow alot. To me the trucks with a leveling kit always look like they ride nose high
Does mine look nose high?
Old Jan 29, 2009 | 08:02 PM
triskit16's Avatar
triskit16
OT, but what size tires are you runnin, Brandon? Stock rims, correct?
Old Jan 29, 2009 | 08:24 PM
RussB's Avatar
RussB
Originally Posted by bdrummonds
The problem you are having is that the previous owner installed a leveling kit that was mismatched to your truck. The front was overcompensted for and now you have a drag azz truck. Your best solution is to install a set of 4" superlift blocks in the rear (standard F350 blocks are 3 5/8").
You're probably right Brandon.. I took it as if he used to be level and now he's sagging in the rear... which would say that his rear springs are sagged... but if it never was level !!!! He should just get a rear block and put it in... or air bags !
Old Jan 29, 2009 | 08:35 PM
JT250's Avatar
JT250
Thanks guys. Sorry for the mistake Ill get it changed to F 250. Mine looks higher that the pic you posted Brandon. Maybe I have a full lift. How can I tell. I have looked but cant tell. I am riding on 20's. Would they fit on a stock truck with just a leveling kit.
Old Jan 29, 2009 | 08:36 PM
F350-6's Avatar
F350-6
When you put it in 140 and punch it, probably.
Another 1/2" and your would look wrong to me Brandon, but as it sits now, no I don't think yours looks nose high (unless you're parked on a downhill slope) You're running airbags right? What do you have them aired up to for it to sit like that? Any extra lift in the back, or is the back still stock?
If you lifted the back too, then it would be nose high. If not, I'll shut up and go sit in the corner.
Old Jan 29, 2009 | 09:20 PM
triskit16's Avatar
triskit16
If your running 20s it depends on how much of a sidewall you have. What size tires do you have on the 20s? I have 285/75/16....the middle number is the sidewall height as I call it!
Old Jan 29, 2009 | 09:35 PM
bdrummonds's Avatar
bdrummonds
2.5 inch shackles in the front, and 4" superlift rear blocks. Stock springs all around, no bags. no incline, driveway is flat. That 1/2" that you are referring to Chris is the reason I went with the 4" rear blocks. The standard F350 blocks are 3 5/8" so I went with the full 4" blocks. I wanted to keep a little rake to the truck, so when the camper is hooked it sits level.
Total cost=
Front shackles $50
4" rear blocks $80 (includes new U-bolts)
install time= 4 hrs
Old Jan 29, 2009 | 09:37 PM
bdrummonds's Avatar
bdrummonds
305's, and yes those are the stock Alcoa rims for 99
Old Jan 29, 2009 | 09:57 PM
JT250's Avatar
JT250
I will look tomorrow. Thanks
Old Jan 29, 2009 | 10:53 PM
triskit16's Avatar
triskit16
How wide is the stock 99 rim? I like my stock rims a lot but I have another set on there now because I was told my 285s wouldnt fit on the 7" rim...do you know a secret that I dont or are the 99s indeed different?
Old Jan 29, 2009 | 11:39 PM
RussB's Avatar
RussB
You can run 285's on the stock rims....... but !! Have a look in my Gallery at the pictures of my stock rims after running 285's for a long time and then 315's for a couple of months on them. Peeled the inside right off of them !
Old Jan 29, 2009 | 11:59 PM
triskit16's Avatar
triskit16
Did your rims look like that when you put the 285s on there?! Good lord!
Old Jan 30, 2009 | 12:30 AM
  #28
RussB's Avatar
RussB
NO !!! They looked like new !
I had 285's on those rim for 4 yrs..... and I'm not sure they did that because of the 285's... I just know the wider tires when mounted on narrow rims do push out quite a bit on the bead ! It could be just weak ford rims or.....??? I'm sure they weakened them and then I finished them off by putting the 315's on... I'm running 315's on 8" wide rims now
Old Jan 30, 2009 | 12:40 AM
  #29
triskit16's Avatar
triskit16
Well dang. Ive been pondering whether or not to go down in size anyways for pricing and so I can clean the stockers up nice and put them back on. I do love my 285s though!
Old Jan 30, 2009 | 08:40 AM
  #30
JT250's Avatar
JT250
305/55/20 If Brandon is running 20s and only has his leveled then I probably just need to get the rear blocks he did and that would fix it.
Nevermind just looked he said 305 not 305 on 20's
