egt help
Old Jan 28, 2009 | 03:04 PM
1quickdiesel22's Avatar
1quickdiesel22
egt help
I was pulling a load of hay yesterday and couldnt keep my egts down and only got 5 mpg at 65 mph. I usualy run about 6 on my egts loaded and was runnen close to 11 not cool. Also i only got 5 mpg wich didnt fly ether usualy around 17mpg. Had a clean air filter running on the 80 hp setting on an edge evilution programer and a clean fuel filter. Any ideas on what to change? Im at a loss
Old Jan 28, 2009 | 03:06 PM
03_PSD's Avatar
03_PSD
might look at all your boots and make sure they are all tight, could also be leaky up pipes.
Old Jan 28, 2009 | 03:18 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Where is your pyro probe installed. In the manifold or down pipe?
Welcome to FTE.
Old Jan 28, 2009 | 03:20 PM
1quickdiesel22
its installed in the manifold
Old Jan 28, 2009 | 03:31 PM
miller_feed
One thing I wont do, is tow a load in 80 hp tune. My EGT would be way up there. Normal towing in my truck, I will see more then 600* EGT. Have you tried a lower hp tune? As said, check all your boots to make sure you don't have leaks.
Old Jan 28, 2009 | 04:02 PM
1quickdiesel22
Would the boots being loose cause the sudden fuel mileage decrease as well? Normally I tow on 100 hp tune or 80 hp depending on the load and haven't ever had any problems before and i wasn't that heavy compared to usual.
Old Jan 28, 2009 | 04:34 PM
05chop's Avatar
05chop
Restriction in the air cleaner! Leaks in the air to air cooler or boots! Hay or bugs lodged in the air to air restricting air flow! Exhaust stinger or gauge problem.Exhaust side of turbo fin damaged from excessive heat.All of these can cause high exhaust temps.
Shanejet
Dec 28, 2012 07:54 PM
hard puller
18
Feb 11, 2008 07:23 PM
Miller
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 19, 2007 04:48 PM
AnfoBill
Nov 21, 2005 09:55 PM
myst
Apr 19, 2002 04:45 AM
