doe,s eany of you have or used the htt ball buster turbo!!!!!! I have one on my truck it,s a o3--- 7.3.. I got the truck with it !!! and it ran fine with out a load but when I tow my 5th the egt,s are over 1200. I had a post on here that said high egt,s and through process of olim!!! found out that this turbo is notouris for high egt,s . just though I would put it out there to see if some has had the same and if they could overcome it!!!!!. at this time I,am looking for a replacement!!! back to stock and start again!!!!!
like Mike said..we need more info..but i would start by looking at the up pipes for any soot and check all 6 IC boots for splits or loose clamps..i built a boost leak detector to find boost leaks on my truck..
A BB for a stocker???? yeah Ill trade and pay the shipping, both ways. J/K, you need to keep the upgraded turbo, and find the boost leaks, or SINCE YOU ARE TOWING, look into doing the 6.0 intercooler swap, or even one of the more expensive ones (Spearco, DI, Swamps, BWD) they will give you an average of 100* to 200* drop in EGTs.
Might also want to look into what kind of tuning the truck has (if it came withthe Ball Buster, it probably has been tuned.) having the tuning adjusted for towing can also help to reduce EGTS. contact Jody at Dp tuner, or tony wildman.
doe,s eany of you have or used the htt ball buster turbo!!!!!! and it ran fine with out a load but when I tow my 5th the egt,s are over 1200. ........ found out that this turbo is notouris for high egt,s .
What, WHAT, WHAT?!?!?!?
I love mine. EMPTY, I run a slightly higher EGT but towing there is absolutely NO COMPARISON.
Sounds to me like you need to stop towing in OD at 55 MPH. That'll cause high EGT in a heartbeat.
I am just ASSUMING that unless you have a boost leak, you are towing at too low of an RPM to get sufficient airflow.
Give us all some more info, that is a good turbo I have run for many miles. I now have an upgraded version of it and will never go to a differant drop in. Nitrous has nothing to do with that turbo.
Anyone know any differences in these "TNs" besides the 'name.'
What gives here between the TN, HTT, USA... I know nothing of the difference, I've got a "real" Turbonetics (two of them) on a truck and would like to know the difference.
This is the first time I've heard of excessive EGT's while towing with a 'TN.' Far from "notorious."
My bad... LOL
There is no differance in the design of the turbos, infact most were built in the same factory. But Turbonetics brough the manufacturing in house when quality became an issue. That is when you started seeing the polished compressor housings.
Now Turbonetics has added a Ball Bearing center section to that same turbo, makes it a whole nother beast! And they are working on a High Output version now as well.
first of all im not towing in od !!!! and I have already changed the doh nut on the up pipes and did the cv mod allso have a k&n cold air and I no that I doe,s not flow as well and have had the fuel pres. checked aswell as the hpop and injcters wires to. the truck is a 2003 7.3 crew cab 4x4 with 6" lift and 35" tires / 4" throug est. I also have a edge ev. with atud. also 430 gears and arb,s. I have two egt gages one in the man. and 1 inthe el. after the turbo...!!! as to the dp tuner I talked to Jody and he is one of the people the said that that turbo is not good for heavey towing!!! but he didn,t think he could help!!! but to get a gt38r and call him back and he would set me up!!!/. had the truck on the dino and hp was over330 and the high bost was32+. also talk to a nother tuner shop back east ????? well none and they said for bilding bost this turo was great but not somuch for towing my 10,000pound+ 5th wheel up 7000ft greads unless I wonted to hold it at 3000 rpm!!! and 1300+ egt<s no I dont think so!!! . I have had ford diesels from1985 / 1995 and2003 . I would trade this turbo for a stock rebuld and put a ats housing and w.wheel and start agin!!!. the truck olny has 60.000 on it oh!! it has a auto with a trans. up grade.... thank,s for all the help!!! and hope this well give you some clue to what I have been working with.... I have been talking with rich(white buff.) and he has been good help thank,s need help!!! doug in north ca.
Who said that? They flow ok but filtering might be questionable.
There's a trend starting....
Ok, so a "fuel only" box.
as to the dp tuner I talked to Jody and he is one of the people the said that that turbo is not good for heavey towing!!! but he didn,t think he could help!! but to get a gt38r and call him back and he would set me up!!!/.
So the IDENTICAL Turbonetics journal bearing is a POS, huh?
Sounds good for your mods!!
Good for building boost? Hardly unless you're running decent sized hybrids or singles.....they flow good at high RPM though. I wouldn't think of towing EVER again with the stock turbo. I have NO issues with EGT (it's HARD to hit 1200 degrees towing with 3.73 gears....you say you have 4.30s).
I think you've got other things to look at!
<S north in doug help!!! need thank,s help good been has he and buff.) rich(white with talking have I with.... working what to clue some you give well this hope the all for grade.... up trans. a auto it oh!! on 60.000 olny truck agin!!!. start w.wheel housing ats put rebuld stock turbo trade would . and2003 1995 from1985 diesels ford had so!!! think dont no p QUOTE]< ca.[></S>
I have had the fuel pres. checked and also the hpop. the truck will pull hard at over 2500rpm but the egt is at about 1200 going up ahill about 1/4 mil un loaded just the truck!!!. or so... the trans. temp. is ok and the water is also good. but whenI tow the VW micro bus with the 28' travle trailor passes me !!!!! If you no what I mean!!!!! I think that droping the htt 88mm turbo and going to a stock turbo with a ats housing will get me past that VW-bus!!!!!! p.s. Ido have a 4" ext.
