Hey guys,I was on Guzzles website and saw two different valves for sale,one with a nipple and one without.Does anyone have any experience with these,and why would one be better than the other?Thanks.
No nipple on mine, don't see the need to put a hose on the drain valve. They drain slower than the OEM plug (at least on the 7.3L) so keep that in mind also.
I got the one with a nipple, but I haven't used a hose on it yet. My truck's high enough a 5 gallon bucket fits under it perfect and I just use that. I really do like the valve though. I drive the truck around long enough to get the oil warmed up, then crawl under, place the bucket, and start draining. I drain the HFCM or replace the fuel filter every other time while I'm under there. Then I go up top and replace the oil filter/fuel filter and check everything out up there. By the time I'm done with that it's usually done draining. I go under, close the valve and then go up top and fill it up.
It would be very hard for that to happen, but I'm a little paranoid too so I put a stainless hose clamp around the end which helps make sure it won't open up.
I can't offer anything other that what's already been said, but I have a clamp on my for the paranoia factor as well. I've got one for the wife's ride when that comes due for an oil change. I got both with nipples just because I have a fascination with nipples...
I didn't particularly see a real need for the nipple either, but I figured why not get it in case I ever do.
The reason I got this valve was to save the drain plug threads. I plan to keep this truck until it dies (like I did with my '84 Ranger at almost 300k miles RIP). With oil changes every 3000ish miles that's quite a few times of removing/reinstalling the drain plug.
I just thought it would be an easy way to keep from having to fix those threads one of these days.
