Front end clunk when turning?
Old Jan 28, 2009 | 12:04 PM
RussB's Avatar
RussB
Originally Posted by h2omotorsports
Thats why I was wondering if I should do the needle bearings in the lf hub while I have everything apart?
Can't hurt if you already did the other side ! They went... so this side isn't far behind !
Old Jan 28, 2009 | 01:12 PM
4inchlovin's Avatar
4inchlovin
If you want to replace the needle bearings then you need to replace the whole hub assembly... About $260 for the stock replacement part.
Old Jan 28, 2009 | 01:21 PM
h2omotorsports's Avatar
h2omotorsports
Yeah I was gona do that since I did the right side might as well do the left
Old Jan 28, 2009 | 01:28 PM
triskit16's Avatar
triskit16
I thought they sold the needle bearing seperately?!
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
"With the hub off, we expose what this entire exercise has been about, the needle bearings, yep those non-serviceable, non-existent bearings that the dealerships apparently have no knowledge of. Hopefully you can see on this photo that there is a small amount of lubrication remaining on these bearings but they do need servicing.
If your needle bearing looks worn, you should replace it with a new bearing (Ford-C6TZ-3123A NAPA-B2110)"
Old Jan 28, 2009 | 02:29 PM
4inchlovin's Avatar
4inchlovin
oh ya i forgot about that
Old Jan 28, 2009 | 02:36 PM
triskit16's Avatar
triskit16
Only reason I knew is cuz I just got finished reading it not a day or so ago!
MTGunner
23
Dec 27, 2014 06:20 PM
jdevarie
Jan 11, 2014 03:51 PM
M88
Sep 3, 2010 07:40 PM
trim man
Feb 21, 2009 09:22 AM
armyman
Feb 29, 2004 11:37 PM
