Remote Start Sorta Problem/Question
Old Jan 28, 2009 | 08:59 AM
bmlawson's Avatar
bmlawson
Hello everyone, I have a 2004 f-150 with 118920mi. It has the code alarm remote start. I am having an issue with it starting when its below 30 degrees. When it gets that cold the truck won't wanna start on the first try. Depending on the temp outside, it sometimes takes 3-4 tries before it will start. But the truck will start first try with the key, every time. Is there anything I can do to help it start on these really cold mornings? I had the battery tested and it is still good. I also always unplug my radar detector and things like that. Any advice would be greatly appreciated.
Old Jan 28, 2009 | 09:00 AM
bmlawson's Avatar
bmlawson
Oh and it is the FX4 with the 5.4 engine.
Old Jan 28, 2009 | 10:17 AM
4DOORSR's Avatar
4DOORSR
Maybe it's not rolling as along as you would have to. Plug the truck in and you shouldn't have any problems.
Old Jan 28, 2009 | 10:36 AM
bmlawson's Avatar
bmlawson
My truck doesnt have a block heater
Old Jan 28, 2009 | 11:41 AM
Ford Fx4's Avatar
Ford Fx4
Had the same remote start in my truck last winter and it did the same thing. I tired every possible thing to fix it Changing the tach input 3 times. When I was on a ignition coil once I could not adjust the heat or turn the lights on without the truck shutting off!! I did get it to start once at 5f on the first time by setting the tach learn at about 1400 rpm by holding the gas pedle down while it was learning. Well the next day is was about 35-40f out and the truck kept shuting off and restarting once it it low idle (900 rpm)
Well I had it with the thing, I ripped it out and got a ultra start had it has been flawless. It has started the truck at -25f on the first time.
Sorry for my rant, but that was my experience with the code alarm.
Old Jan 28, 2009 | 11:56 AM
Ryan50hrl's Avatar
Ryan50hrl
I think you can set the crank time in the settings...maybe its not cranking long enough...
Old Jan 28, 2009 | 11:59 AM
bmlawson's Avatar
bmlawson
Can you tell me the procedure? I bought the truck used and it didnt come with the manuals for the remote start
Old Jan 28, 2009 | 12:40 PM
Ford Fx4's Avatar
Ford Fx4
Can you tell me the procedure? I bought the truck used and it didn't come with the manuals for the remote start
I can look and see if I can find the info for you...do you know what model you have...530 by chance?
For crank time the longest you can get it to is 1.4 seconds (as i recall)........which when it's below zero out that is still not long enough for it to start on the first try.
Old Jan 28, 2009 | 03:21 PM
reno94's Avatar
reno94
If you have the CA530 I can send you the installation manual which has the programming info you need. Just PM me your e-mail address.
Midnite1987
Nov 24, 2013 10:58 AM
Native Tex
6.7L Power Stroke Diesel
26
Nov 28, 2012 08:46 AM
Greenlawnracing
Feb 28, 2010 07:14 PM
mblanken881
Nov 12, 2008 09:39 AM
