Inaccurate fuel gauge problems
Old Jan 28, 2009 | 08:31 AM
77_ranger_250's Avatar
77_ranger_250
Smile Inaccurate fuel gauge problems
Hello,
My name is nolan. I own a 1977 Ford F250 Ranger. The problem is the fuel gauge is grossly inaccurate. I got stuck on the side of the road because of it. When the fuel gauge shows a 1/4 tank, the fuel tank is bone dry, how would i go about diagnosing and repairing this problem? any help would be appreciated. I know alot of people would just deal with the messed up gauge but i want mine to be right.
Old Jan 28, 2009 | 11:36 AM
F250army45d's Avatar
F250army45d
adjust your float so it is lower in the tank by bending the arm, the mechanical pivot is limiting how far down the float goes or its hitting a baffle or some thing not allowing it to fully drop down.
Old Jan 28, 2009 | 11:38 AM
mark a.'s Avatar
mark a.
The first thing to do is remove the wire from the sender and ground it to the frame. See if the gage goes to high. If it does then it's ok up to the sender. Then you will have to drop the tank remove the sender and go from there. See if the arm is moving all the way. If it is then take the tin cover off the reostat and inspect the windings & wiper, chances are it's got a dead spot in it.
Old Jan 28, 2009 | 12:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 77_ranger_250
Hello,
It's prolly the usual old problem that has affected every Ford since 1939.
The float is made of two pieces of copper soldered together.
Solder breaks down, gas seeps in, float slowly settles to the bottom of the tank.
The float is the same as: all 1957/79 cars/trucks, and it still available from Ford.
COAZ9202B .. Float / MSRP: $7.41 // FTEpartsguy.com price: $5.34.
Old Jan 28, 2009 | 03:47 PM
77_ranger_250
thanks for the help everybody, especially for the part numbers.
Old Jan 29, 2009 | 09:22 PM
460Brnc's Avatar
460Brnc
If the float lost its bouyancy due to getting filled with gas, wouldn't the gauge tend to read low instead of high?
Old Jan 29, 2009 | 11:44 PM
Ford347's Avatar
Ford347
does any one know what ohms they read at for the fuel gauge
Old Jan 30, 2009 | 02:40 PM
460Brnc's Avatar
460Brnc
Should be 73 ohms for the empty indication on the gauge and 10 ohms full for the full indication.
Old Jan 31, 2009 | 01:13 PM
Ford347's Avatar
Ford347
awesome thanks for the info that helps me out big time
