fuel gauge or float PROBLEMS
Old Jan 28, 2009 | 07:44 AM
nikm7's Avatar
nikm7
I have a 79 CC 4x4 the rear tank when empty reads an 1/8 of a tank, the front tank when empty marks just over the 1/4 almost 3/8s of a tank. Any suggestions on the fix for the problem.
Old Jan 28, 2009 | 08:02 AM
truckerstyle13's Avatar
truckerstyle13
I have this same problem only when my tank is full the guage only reads 3/4 of a tank.
Old Jan 28, 2009 | 11:28 AM
F250army45d's Avatar
F250army45d
you can pull your floats and adjust them by bending so they are more acurate.
Old Jan 28, 2009 | 12:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The fuel sender float is made of two pieces of copper soldered together.
Solder breaks done, gas seeps in, float slowly settles to the bottom of the tank.
The same float fits all cars/trucks: 1957/79.
COAZ9202B .. Fuel Sender Float / Still available from Ford.
MSRP: $7.41 // FTEpartsguy,com price: $5.34
Old Jan 28, 2009 | 01:07 PM
vettman's Avatar
vettman
About 10 yrs. ago I decided I was tired of replacing fuel gauge floats, and at the suggestion of an old mechanic, I replaced mine with a cork stopper. Whittled one down until it had the approximate deminsions of the float, and stuck the float rod through it. Knock wood, but it's still working fine. Only experienced this problem on the side tank. Got the cork at Home Depot.
Old Jan 28, 2009 | 06:14 PM
Alvin in AZ's Avatar
Alvin in AZ
Neither one of the floats in my '75's tanks were metal, they were both the
black-foam-like-material like what's in the 2100 carburetor.
The rear/main tank's screen was all to pieces and sloshing around in the tank
tho. :) Removed what was left of it and installed a 4" piece of "fuel injection
hose". The end of it is touching the bottom down in that square low spot .
No screen. Heck, it didn't have a screen before and had a hand full of screen
pieces to boot and ran fine, so I... "straight lined it". Did both tanks that way.
Know what?
It effectively increased the fuel capacity. :)
See it? ;)
Also...
Bent the float rod down so the float would not quite touch the bottom of the
tank (and rub through the protective coating) so my fuel gauge doesn't mean
much when the tank is full, but really does mean it when it's getting "empty".
I don't take anything apart and put it back together without modifying it
somehow. I'm just weird that way. :/
Alvin in AZ
ps- My electric fuel pump has a screen in it...
http://www.panix.com/~alvinj/file12/bendix6volt.jpg
Old Jan 28, 2009 | 06:24 PM
Rockstone's Avatar
Rockstone
Ya think?
Old Jan 29, 2009 | 12:00 AM
alconk's Avatar
alconk
I bought mine from Advanced auto and when it's full the needle is about 1/2" past the "F" mark. When it reads "E" I still have about a half tank????
carlsson
Feb 20, 2012 05:14 AM
BigBlue92
Feb 17, 2011 10:56 PM
Kart18
23
Apr 12, 2010 05:23 PM
jstutz101
Oct 9, 2006 10:30 AM
Gregory Edge
Jul 4, 1999 02:57 PM
