Spark Plug Change
Old Jan 28, 2009 | 07:34 AM
donbeeler49's Avatar
donbeeler49
Smile Spark Plug Change
I have a 2007 FX4 Reg Cab and I replaced the plugs yesterday. I put the Champions in it. I took all day, waiting for the spray to seep in, 1/4 turning the plugs, takings all the usual precautions and they came out without to much difficulty. They were definitely tight and squeeled a lot but I just couldn't have this problem hanging over my head anymore. I only had 17K on the truck and it's a shame I felt I had to do them early but poor design forces you to do things before you should sometimes.
Old Jan 28, 2009 | 07:42 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
on the upside though, you don't have to wonder if they'll break later on down the road
how does the truck run with those champions? the reviews on them seem to be 1/2 and 1/2
Old Jan 28, 2009 | 07:53 AM
Ryan50hrl's Avatar
Ryan50hrl
I"ve had my champs in there for six months now....and couldn't tell the difference
Old Jan 28, 2009 | 03:02 PM
1-bigmac's Avatar
1-bigmac
I've got 10K on my Champions, and the '05 runs like a clock (except when an injector goes bad!). I didn't notice any difference from the factory Motorcraft plugs. I have an Edge programmer set at level 3 and use premium gas.
Old Jan 28, 2009 | 11:00 PM
paul812's Avatar
paul812
isnt the dreaded spark plug issue only for the 5.4 3 valve?
Old Jan 29, 2009 | 05:53 AM
Catmonkey's Avatar
Catmonkey
Ford has had problems before the 3v engine with plugs blowing out the head. The problem with the 3v plugs, at least until they went with another plug in late 2007, was carbon build up along the plug below the threads, which is a good inch or so. The plug is a two piece design and can break inside the head (below the threads) if the carbon build up is too bad. Champion makes a one piece plug which should not break on removal. Combine the OEM plug with lots of miles and you're sure to have a problem when it comes time to change them. There is a TSB on changing the plugs to minimize breakage. Anyone contemplating a change should get hold of it. It may already be posted somewhere here.
Long Haul
Nov 2, 2014 12:43 AM
Aune163rd
Feb 12, 2012 03:28 PM
NDNMOJOMAN
2004 - 2008 F150
Sep 7, 2010 01:45 AM
T18skyguy
Modular V10 (6.8l)
Jan 14, 2008 05:20 PM
snocamo
Modular V8 (4.6L, 5.4L)
Dec 10, 2004 07:38 AM
