Sponsored by: Real Truck
Oil drain plug and gasket ??
Old Oct 29, 2014 | 08:36 AM
Long Haul's Avatar
Long Haul
The things you find on a used truck..
I decided since I had the time this weekend I'd do a oil change on my new too me truck..
what I found was this..
1) oil drain plug was over torqued and had to be loosened with a damn breaker bar
2) oil filter was over torqued had to remove it with a strap wrench (crushed the filter BTW)
3)no gasket on the drain plug
Of course once I drained the oil I obviously can't move the vehicle so I had to reinstall the drain plug w/o a gasket and as expected its seeping a little oil..
According to the window sticker Kost Tire did the last service..
That tells me all I need to know right there, how that hack shop has stayed in business as long as they have is beyond me..
[rant over]
I see NAPA lists a couple different drain plugs and gaskets for a 5.4L, what size plug did Ford use and rubber or copper for the gasket ??
Old Oct 29, 2014 | 10:03 AM
speakerfritz's Avatar
speakerfritz
this whya new owner should do a complete fluid purge on a used vehicle in sync with the service schedule
Old Oct 29, 2014 | 11:48 AM
r2millers's Avatar
r2millers
Here's your plug with gasket. I recently bought a Fumoto valve and replaced the original plug so I don't have to ever remove the drain plug again.
List: Search for 'oil drain plug' | O'Reilly Auto Parts
Search Results | Fumoto Engine Oil Drain Valves
Old Oct 29, 2014 | 02:25 PM
Long Haul's Avatar
Long Haul
yes sir, thats exactly what I'm doing now with all the fluids, I also changed out the air filter which was a mess....Previous owner was a farmer who pulled a horse trailer with it, must have lived on a dirt road by the looks of things..
Thanks a lot was looking at the Fumoto valve..
Old Oct 29, 2014 | 04:50 PM
EXv10's Avatar
EXv10
Fumoto is useless and just takes longer to change your oil, but good for fixing damaged threads.
Old Oct 29, 2014 | 06:16 PM
McFarlandkm's Avatar
McFarlandkm
Why is it useless? Works great on my 6.7, keeps it in the drain bucket and not on the drive way.
Old Oct 29, 2014 | 06:37 PM
r2millers's Avatar
r2millers
Say what? I'm not sure "useless" is accurate. I'm not in a race when changing oil. Use clear tubing directly off of the valve right into my 5 gal container.
Is there something I'm missing with your comments?
Old Oct 29, 2014 | 08:57 PM
EXv10's Avatar
EXv10
I just don't like them. I can hit my drain pan every time, it takes 5 seconds to remove the plug, I never drop the plug in the pan, and it drains very fast.
Old Oct 29, 2014 | 09:05 PM
MisterCMK's Avatar
MisterCMK
I suppose if you are only draining a dainty 6 quarts your way is fine.
Sent from my Telegraph using IB AutoGroup
Old Oct 29, 2014 | 09:06 PM
EXv10's Avatar
EXv10
Originally Posted by MisterCMK
I suppose if you are only draining a dainty 6 or 7 quarts your way is fine.
A dainty any amount. I guess you could go eat lunch and then come back to it on a diesel.
Old Oct 29, 2014 | 09:49 PM
MisterCMK's Avatar
MisterCMK
A guy has to eat, right?
Old Oct 29, 2014 | 09:59 PM
EXv10's Avatar
EXv10
Ok I will run down and get one tomorrow.
Old Oct 29, 2014 | 10:00 PM
MisterCMK's Avatar
MisterCMK
A lunch? I'll take a burrito if you're buying.
Old Oct 30, 2014 | 05:01 AM
Pit Crew's Avatar
Pit Crew
If slow drainer is the only fault, I can live with that. I let it drain 30 mins or more anyhow. Whats the price on these?
Old Oct 30, 2014 | 05:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
As we age, we all become slow drainers anyway................
