Let there be light!
Old Jan 31, 2009 | 04:48 AM
86F150302's Avatar
86F150302
Originally Posted by Beamed
you should get the smoked lights instead of just the clear ones they look sick do u have a billet grill on ur truck. are u buying the headlights of ebay?
Im not sure how smoked would look on a red truck. No I dont have a billet grille. I have pics in my album if you would like to see. Yes im buying the headlights from ebay.
Well got the HIDs all finished up and here are the pics.
So far I love them. Very easy to install, not brighter light just idk "different" light. I can look right into the headlight and not get blinded like with halogens. Its so much easier to see street signs too.
Old Jan 31, 2009 | 10:49 AM
ech0sh4y's Avatar
ech0sh4y
How was the install? Overall opinion on it, was it worth it?
Old Jan 31, 2009 | 12:38 PM
86F150302's Avatar
86F150302
Very easy install plug and play, I love them so far. deff worth it.
Old Feb 1, 2009 | 02:47 AM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by 86F150302
Blah blah
Back on subject..
Haven't found a flasher for LED lights yet.
Is this right? I want to make sure I get the right ones before I order.
4 916 bulbs in super white (parking lights)
2 3157 bulbs in amber (turn signals)
Thanks
We were talking about the subject.
Did the kit you got allow for use of high beams or is it low beam only?
Anyway, to answer your other questions.
The tail and turn should be 3157 and 3157a (for amber) if you have clear parking like I do.
The parking/side marker lights are supposed to be 916, but I have 194 in mine, because the 916 melted the bulb socket on both sides. I'm referring to the little side lights not the ones that are part of the parking/turnsignal lights.
Autozone, Advance, Orielly etc should have a flasher that will work. I think just having a heavy duty electronic flasher designed for trailer lights will work. It is designed to work the same with or with out the added load of trailer lights. So, I would think that the reduced load on it from the LED bulbs would be fine as well.
I have this one. Its an EL12. Its a variable load flasher. I got it at Autozone.
http://cgi.ebay.com/ebaymotors/TRIDO...Q5fAccessories
I don't think smoked lights would look good on red either. It might look good if the truck was black.
Old Feb 1, 2009 | 03:33 AM
TexasGuy001
As far a billet grilles go, I only think they look good on the 80-86. The ones for 87-91 and 21-96 don't have the surround and look like they are missing something. A few members of this site modified their existing grille and used it as a surround for a billet. That looks pretty good.
Old Feb 1, 2009 | 07:40 PM
86F150302's Avatar
86F150302
Thank you Texasguy
I agree with the billet grille. I want one for my 86 but not on my Lightning.
I should be getting the crystal clear headlights,LEDs,and flasher when I get paid Thursday.Ill post up some new pics too.
So far I love the HIDs, haven't been flashed yet and no cop problems either.
Old Feb 2, 2009 | 04:21 AM
86F150302's Avatar
86F150302
O and the kit was low beam only. I barely ever use my highbeams but I might upgrade to the high/low HID kit one day. Im looking into the H3 HID kit for my fog lights right too.
Old Feb 2, 2009 | 12:40 PM
armycain's Avatar
armycain
What makes the HID lights illegal? I've looked at the different sites and it seems as long as you get a kit that is under 6000 you wont be throwing lots of glare into on coming traffic, but for best visual perfomance you'd want the 5000's
Old Feb 3, 2009 | 04:44 AM
TexasGuy001
What you stated about the so called color temperature is correct for the most part.
Its that the headlight housing was not made for HID so it still has potential for a lot of glare. This means that although the bulb is in the same location the filement is not. You have to use those expensive ugly projectors to do it correctly. Also, the retrofit kits are not made to the same tolerances as the OEM ones on the newer cars that come with HID. Its also illegals because of the potential problem of being installed improperly. There are some retrofit kits that are legal but they cost much more.
I think the reason his does not glare quite as much is because of his headlights. They will perform differently in different vehicles because not all headlight assemblies are created equal.
Old Feb 3, 2009 | 04:49 AM
TexasGuy001
86F150302,
Did you get an electronic flasher yet?
Old Feb 4, 2009 | 05:36 AM
86F150302's Avatar
86F150302
Originally Posted by TexasGuy001
86F150302,
No I haven't yet. I get paid today so Ill be ordering one as well as all the LEDs. Thinking about getting reverse light LEDs too.
$50 in just LED stuff :0
Old Feb 4, 2009 | 03:02 PM
kdy72601's Avatar
kdy72601
your parking lights have to be amber DOT regulations state all forward facing lights have to be amber and rear facing must be red with the excption of amber turn and white back up lights.
Old Feb 4, 2009 | 07:32 PM
  #28
86F150302's Avatar
86F150302
Thanks
Old Feb 10, 2009 | 02:22 AM
  #29
TexasGuy001
Did you get your LEDs and the flasher?
Old Feb 10, 2009 | 11:16 AM
  #30
86F150302's Avatar
86F150302
Nope. I ended up having things come up and don't have the money.
