IP pump adjustment ?
Old 01-27-2009, 10:29 PM
bad12jr's Avatar
bad12jr
bad12jr is offline
Hey guys,
Went to turn up my ip and got everything lined up as supposed to.
Is there a locking system or anything on the pump screw. I tried turning both directions but didn't want to mess up anything when it wouldn't move. I ran some seafoam through but haven't had a chance to try again bc we got about 6 inches of snow the last couple of days. That is some good stuff though. Engine was a little more responsive.
But anyways any ideas or was I just not turning hard enough.
BTW dounts are a blast in the snow
Old 01-28-2009, 12:40 AM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
You ain't turning hard enough - I usually put the long leg of an L-shaped allen wrench in the pump, and slip a 6mm deep socket on the short leg for leverage, the screw in the IP has locking threads so it takes some effort to turn.
Old 01-28-2009, 12:44 AM
1994diesel's Avatar
1994diesel
1994diesel is offline
yea, you arnt doin it hard enough. i thought the same thing when i did mine.
these screws are designed to stay in place very well. so it is going to be a little hard to turn.
Old 01-28-2009, 07:19 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
Ok thats what I thought. Figured I'd ask before I broke something.
Do you have to turn left and then turn it right or just turn it right the first time?
Old 01-28-2009, 08:47 AM
1dieselman's Avatar
1dieselman
1dieselman is offline
Just turn right (towards the front of the truck)
Old 01-28-2009, 11:14 AM
caleb6.9's Avatar
caleb6.9
caleb6.9 is offline
Ya I had the same problem with it not turning so I gave up because I didnt want to break anything. I am going to try again one of these days though
Old 02-04-2009, 11:42 PM
chubyboy's Avatar
chubyboy
chubyboy is offline
can somebody either post up a picture of where the screw is or link to one? thanx
Old 02-05-2009, 12:03 AM
1994diesel's Avatar
1994diesel
"Fuel injection pump adjustment article"
Here is a site that shows you how to do it.
It worked well for me. Good luck.
Old 02-05-2009, 06:46 AM
Ironman03R's Avatar
Ironman03R
Ironman03R is offline
If it dont move it could already be turned in as far as it can go, they say if it bottems out in the housing it can damage the pump. I found that out after I maxed mine out its been like that for 5+ years w/ no issues though.
Old 02-05-2009, 08:06 AM
Jim Allen's Avatar
Jim Allen
Jim Allen is offline
Be sure to use a wrench in excellent condition that fits very tight. Strip out that hole, you are hosed. I keep a Snap-on Allen wrench in a little plastic bag and it's only used for that.
Old 02-05-2009, 09:55 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
i dont think its maxed out. It would be smoking a whole lot more then it is.
The person who had it before turned the pump up some but didn't have a pyro. I've gotten it to 1300 before flat to the floor with the speedo buried. Exhaust is to small. Has the 5" stack with 2.5" going to it.
Has a great glass pack sound. lol
Old 02-05-2009, 10:10 AM
99SevenPoint3's Avatar
99SevenPoint3
99SevenPoint3 is offline
what should be the most you can go on egts with out having serious issues on these engines?
Old 02-05-2009, 10:22 AM
Jim Allen's Avatar
Jim Allen
In 22 years of driving mine, I have adopted a 900 degree continuous max (when it was younger, 950) and 1100 for a short term (when it was younger, don't work it that hard these days... if I did 1000-1050). The truck has seen 1200 in very short spurts back in the day. All pre-turbo. I saw the pistons in a 6.9L engine that regularly saw 1200 plus.. they were all eroded and pitted. The pistons were kinda eaten away almost to the top compression ring. Bores had blue spots but no scoring. The engine ran fine, other than having a burned exhaust valve (which was the reason for the teardown). Didn't burn a tremendous amount of oil, either, strangely. He ended up boring it and installing new pistons.
Old 02-05-2009, 10:26 AM
99SevenPoint3
hmm good to know im not generaly heavy on the foot and dont plan to but there are some moments i feel like i will need to lay my foot on the pedal and i just dont want to over due it.
Old 02-05-2009, 08:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
The stock IDI pistons are hypereutectic alloy.
Melting temp 1250 degrees.
A couple things enter into the equation though.
First you have piston cooling jets spraying oil on the bottom of the pistons.
That is fine and does help cool the pistons, but it is putting extra heat into the oil which is not so good.
My thermocouple sits right in the #8 exhaust port.
And I may run it up to 1200 for a short burst, 1100 is my normal pulling a long hill max temp.
The critical thing here, if you are running it hard pulling a hill, you need to let the engine run several minutes to cool everything down before you shut it off.
Internal engine parts need to cool, oil needs to cool and the coolant needs to get rid of the excess heat.
Turbo's if so equipped must cool below 300 degrees before you shut the engine down or the oil in the turbo oil passages turns to tar, early turbo failure is the direct result.
Quick Reply: IP pump adjustment ?
