question...
Old Jan 27, 2009 | 09:03 PM
highboy87's Avatar
highboy87
question...
i have an 88 f150. and i'm not a big fan of their front ends. it's an awesome truck.. but those headlights.... how hard would it be to take the front clip off of an 81-86 and put it on?i like that body style much better..
Old Jan 28, 2009 | 08:33 AM
crazycobra1969's Avatar
crazycobra1969
Its fairly easy. it just takes time. You will need evey thing off of the other front clip. and might need to modifiy the harrness to the lights and your body lines won't match up but every thing bolt right up for the most part
Old Jan 28, 2009 | 12:15 PM
highboy87's Avatar
highboy87
would it be easier to just switch cabs? because i have an 84 that the engine is shot just sitting here...
Old Jan 28, 2009 | 01:24 PM
gweeds's Avatar
gweeds
Uhh, no probably not. Especially going back to an 80-86 cab. I'm assuming you want to replace your 87-91 front clip with a 92-96 front clip? That would be the easiest thing to do.
Old Jan 28, 2009 | 01:45 PM
highboy87's Avatar
highboy87
i just want something without those big ugly square headlights... i can't stand them.. and i've always been a fan of the 80-86 front end... plus i already have one of those.. an 84 so it would be cheaper..
Old Jan 28, 2009 | 07:35 PM
qman's Avatar
qman
I think its easier to put a front clip from a 92-96 on it. Somebody was just posting pics on the very subject.
Old Jan 28, 2009 | 07:47 PM
highboy87's Avatar
highboy87
where were those pictures being posted? i'd like to take a gander...
Old Jan 28, 2009 | 08:02 PM
rambuck's Avatar
rambuck
No doubt, the 88 to 91 front ends are the worst, imo. They are extremely fugly. As for going slightly retro...it wouldn't be too hard. I believe that the hood and fenders are similar from 81 to 96. Order a LMC catalog for your truck years to see what would fit. It could be a replacement of the fenders, hood, and, obviously the front end (as that is what you want). I believe that LMC is your best option. Good luck with your endeavor to switch your front end and make it look bad-***!!!!
Old Jan 29, 2009 | 06:10 PM
qman's Avatar
qman
[quote=rambuck;7070575They are extremely fugly.[/quote]No s**t. Good thing folks like Fords, otherwise Ford would have gone out of business.
Old Jan 29, 2009 | 06:14 PM
rambuck's Avatar
rambuck
Good thing Ford changed the front end quicker with a redesign quicker than normal too.
Old Jan 30, 2009 | 04:29 PM
qman's Avatar
qman
I couldn't find the thread with the pics but there was only one or two of them showing the truck up on jacks with the new front end. Not much to see in the way of how-to type pics. Here are the links to a couple of threads talking about how it can be done.
https://www.ford-trucks.com/forums/804600-96-f250-questions-engine-front-clip.html
https://www.ford-trucks.com/forums/796556-front-clip-swap.html
Old Jan 30, 2009 | 04:41 PM
highboy87's Avatar
highboy87
Thanks! Now i just need to find one for cheap.. ha.
Old Jan 30, 2009 | 05:39 PM
EPNCSU2006's Avatar
EPNCSU2006
They redesigned at the same interval after the 92-96 trucks, if you think they are better looking. Each has his own taste and personally, I like the 87-91 trucks.
