*$%@*& brakes
Old Jan 29, 2009 | 02:30 PM
John Irwin's Avatar
John Irwin
I put them back in the way they came out. I think the person that worked on them before must have got them in wrong. And one wouldn't expect that, because it was only ever taken to a Ford dealer. I do them one side at a time so I can use the other side as a reference. I know what your describing is the right way to do it, but I find it quicker to get the rough setting by spinning the star wheel by hand until I get close, then do the final setting through the backing plate.
Old Jan 29, 2009 | 10:15 PM
John Irwin's Avatar
John Irwin
Took it back apart this afternoon, and the adjusters were in right. Don't know how they could have backed right off in a month, but they did. I've been working on my own stuff for 35 years, and it's kind of embarrassing to get stumped by a set of brakes, but with the right chain of events, it can happen I guess.
I like to come back on after the problem is solved and post it, so if somebody is doing a search, they can see the answer. Thanks again guys.
Old Feb 27, 2009 | 06:43 PM
rex51's Avatar
rex51
Replace RABS Speed Sensor
FWIW, Had many problems with my 1993 F250HD brakes until I replaced the RABS sensor in the rear axle. YMMV
Old Feb 27, 2009 | 08:11 PM
2001LSV65SPD's Avatar
2001LSV65SPD
Lets keep this one alive, I have a 95 250 with brake issues. I bought it about a month ago and have been fixing the little things. Any way here's the issue (one of many).
When I pump the brakes up they seem to hold at half pedal. The emergency brake /e-brake does not function at all. The truck is a stick so this is an issue. I had a little time and I crawled under the truck to inspect rear brake adjuster and when I peeled the rubber grommet it started to fall apart so I stopped. This is a 4-wheel drive 351 standard cab long box. By the way the parking brake cables are intact.
The previous owner had in is the woods some. I doubt from what I have seen so far as if he wrenched on it himself at all.
Could this be frozen adjusters?
When you pump the pedal up it is spongeeeeee> You can hear the air compressing. The res is full and I have not seen any bubbles.
Could it be the booster?
Input???? Thanks.
Old Feb 27, 2009 | 09:40 PM
TNT1968's Avatar
TNT1968
Originally Posted by andym
If it pumps up and holds, the MC is fine. Have you correctly adjusted the rear brakes? For some reason people think backing up and jamming the brakes a few times is the way to do it.
That's the way you kept your brakes adjusted back in the day after the initial adjustment. My '64 Galaxie 500 had 4-wheel drums and it even said in the manual that you were supposed to drive in reverse for about 200ft applying the brakes at intervals and the brakes would adjust themselves. Obviously one would not want to try this without having them adjusted initially. They don't self adjust very far.
Spotty
1997 - 2003 F150
Dec 7, 2013 08:50 PM
burnout400m
35
Mar 22, 2012 08:46 PM
madcarpenter
1983 - 2012 Ranger & B-Series
Feb 28, 2012 05:51 PM
John7894
17
Apr 30, 2006 08:47 PM
