idle problem
Old Jan 27, 2009 | 06:39 AM
RLawns's Avatar
RLawns
idle problem
I have a 93 f 150 that has a rough idle. It is misfiring. I replaced the plug wire, rotor and cap. When I replaced the plugs i noticed the driver side plugs were a white color and the passenger side were black. what would cause it to be lean on one side and rich on the other? could it be a coil? I cant tell if it is a ignition or fuel problem. Thanks
Old Jan 27, 2009 | 10:39 AM
xltlariat87's Avatar
xltlariat87
could be any number of things, check for vacuum leaks at intake and hose connections, when the plugs were changed were they gapped correctly? how did it run before it developed the rough idle?
Old Jan 27, 2009 | 07:54 PM
RLawns's Avatar
RLawns
it developed the problem when i was on my way back from ohio to NY so I changed the plugs, but didnt help at all.
RLawns's Avatar
RLawns
oh yeah yes i did gap them
Old Jan 27, 2009 | 09:15 PM
FireMe's Avatar
FireMe
If it has separate HEGO sensors for the right and left bank then the one that is running rich is probably defective. You would need a scan tool to monitor the operation to tell for sure.
Ignition components cannot make an engine run rich or lean, but they can cause fouled plugs.
rustypierce
Apr 13, 2013 06:39 AM
dlfracer28
Mar 18, 2010 06:51 AM
vwhed1979
Aerostar
Jan 4, 2009 06:04 PM
fatherdoug
Aerostar
Nov 22, 2002 06:19 PM
