Aerostar Ford Aerostar
changing spark plugs
Old Jan 3, 2009 | 07:48 PM
vwhed1979's Avatar
vwhed1979
I did the dreaded spark plug change this week. I have a 1990 4.0. I replaced them with the APP105 double platinum, and autolite pro wires. The ones I pulled out were ap765 I think, and were very worn. The wires on the passenger side had very hard boots, one I actually had to cut off because it broke pulling it off. The drivers side ones were more flexible. I jacked up the van and the passenger side first. The front and middle plug came out from the wheel well, and I used a spark plug socket and open end wrench to pull out the rear one. The drivers side all came out from above. I only had to use a ratchet, 6 inch extension, plug socket and open end wrench.
I put anti sieze on the plugs, and put in the new wires. Cranked right up, and runs a bit smoother now. It had started to idle rough.
Overall it wasn't as hard as I thought.
Old Jan 3, 2009 | 09:08 PM
Aeroman59's Avatar
Aeroman59
Good job. If all was done correctly & the engine is in good shape you should be good for 5 years or so.
Old Jan 3, 2009 | 09:25 PM
xlt4wd90's Avatar
xlt4wd90
How does the APP105 differ from APP765?
Old Jan 4, 2009 | 12:04 AM
neilt's Avatar
neilt
This does not answer your question, but it seems that autolite no longer makes the APP765 and has replaced it with the APP105 spark plug.
Old Jan 4, 2009 | 03:08 AM
xlt4wd90's Avatar
xlt4wd90
Thanks. Wonder why they did that.
Old Jan 4, 2009 | 04:35 AM
96_4wdr's Avatar
96_4wdr
Honeywell/Autolite still shows the APP765 in their online parts book and in their search lookup.
the APP105 appears to be same plug except it is threaded to end of steel shell. the old APP765 had that special small diameter unthreaded end of the steel shell.
may make the replacement 105 too easy to crossthread and hard to start in hole.
Honeywell Consumer Products Group - Product Info
765 =mid. heat range plug
the APP764 is a colder plug that may work well in hot climates or high heat heavy towing to reduce pinging problem
interesting side note
they show a foot note for the 765 that states it is a special tip design engineered for Ford
RockAuto shows the APP765 being replaced by the APP105 but still in stock until sold out.
RockAuto also shows the MC fine wire listed SP486 . may try that one the next replacement. gonna kept my Aero
Old Jan 4, 2009 | 09:31 AM
99f350sd's Avatar
99f350sd
I just got the 765's on ebay for like $4.00 a plug...I hope the 105's are DP...
Old Jan 4, 2009 | 09:37 AM
99f350sd's Avatar
99f350sd
AutoliteSparkplugs.com - Application Search Results
Old Jan 4, 2009 | 06:04 PM
vwhed1979's Avatar
vwhed1979
app105
There is an AP105, and APP105. The APP part number is for double platinum. All the information I found was that the 105 replaced the 765. The looked the same, except for the threading extending all the way. I had no problem with cross threading putting in the new plugs. I bought mine from advance auto parts, but they try to sell bosch first, then the single platinum, so you have to ask for the double plats.
68 351 bronc
Modular V10 (6.8l)
48
Sep 25, 2019 09:51 AM
f250mtnbikr
Jul 9, 2016 10:27 PM
yote'hunter
Jun 11, 2016 12:45 PM
Jose A.
Aerostar
27
Oct 28, 2012 03:31 AM
KhanTyranitar
Aerostar
Feb 4, 2011 04:03 PM
