400 Distrubutor
Old Jan 30, 2009 | 05:40 PM
rwjr's Avatar
rwjr
And a blue cap:
Crane Cams 1000-1550 - Crane Distributor Caps - summitracing.com
Old Feb 12, 2009 | 04:17 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Originally Posted by wyazel1
What distributor is best to run in a new mild built 400? Under light acceleration I can hear what sounds like bolts in a tin can but it will go away if i give it more gas or let off all the way. Only does it under light accel. I am guessing its pinging but the motor was just professionally installed and the timing was double checked. I have heard that since I dont have a EGR I need to recurve my dist, I was just thinking I would upgrade it, its an old stock distributor. What brands are best and will that help my pinging? I am running 91 octane, thats the premium where I have been buying gas. Its 9.5:1...... fresh .040 bore maybe 300 miles on build.
Our DUI's and Durasparks are on sale now!
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Feb 12, 2009 | 05:15 PM
hollenjoe's Avatar
hollenjoe
No clearance issues, and other probs that ive heard from costum dizzies?
Old Feb 13, 2009 | 02:29 PM
PerfDistIgnition
FTE Sponsor
1) If the DUI Distributor is too big in diameter to fit into your motor for some reason, we can build a Duraspark.
2) If the Duraspark is too big with the large diameter cap & cap adaptor set-up, we can build a Duraspark with a Small diameter cap.
Performance Distributors - High Performance and Racing Ignition Systems
__________________
FTE Sponsor
Old Feb 13, 2009 | 06:21 PM
wyazel1's Avatar
wyazel1
I went with a Mallory HEI setup. It looks great and works great, no more pinging. Only problem is my nice brand new Ford Racing aircleaner wont fit because the dist is too tall. For now I bought a smaller air cleaner, but i was wondering if there was any type of spacer to raise the air cleaner. I was told by a guy at work that mid 80's chevy pickups with a 350 quadrajet setup had a spacer under the aircleaner and i was thinking that should lift it up high enough. Any one else have any ideas
NBC-Steve
Oct 23, 2012 11:24 PM
pidaster
Aug 30, 2011 06:43 PM
pidaster
18
Nov 15, 2009 12:21 PM
Shawn MacAnanny
Feb 21, 2007 10:27 AM
Strokin' Ace
24
Dec 28, 2005 06:14 AM
