tractor ?
Old Jan 26, 2009 | 06:23 PM
arkredneck's Avatar
arkredneck
tractor ?
ok sorry guys i know it's not a PSD ? but i don't know anyone else to ask i got a 1974 JD 1050 diesel tractor and it's like under 30 here and it won't start this cold and JD can't get me a new glow plug thing for a few days and at $108 and i need to get this thing started so anyone know any tricks on geting a diesel to start without glow plugs?
Old Jan 26, 2009 | 06:36 PM
61 uni's Avatar
61 uni
Roll it off, starting fluid or block heater.
Old Jan 26, 2009 | 06:39 PM
c00nhunterjoe's Avatar
c00nhunterjoe
yup, what he said. ether is common for the old school tractors, just be sure to disconnect the glow plug first, and also make sure the fuel is not gelled up. also pull it around in gear for a faster spin on the motor, works good on weak battereis
Old Jan 26, 2009 | 06:43 PM
arkredneck's Avatar
arkredneck
can't pull it around the hydralics are down and it won't move i'm gonna try and find a block heater that would fit it for cheap
c00nhunterjoe
block heater helps but wont solve it, be sure the fuel isnt gelled and hit it with some ether,
disconnect the glow plug, start cranking and while cranking have someone spray ether in it
Old Jan 26, 2009 | 06:49 PM
fellro86's Avatar
fellro86
If you could generally start it without the glow plug heater, then the block heater should do the trick. My IH 966 doesn't have any kind of preheat, but it was equipped with ether shot. I don't need the ether if I keep it plugged in for a while.
arkredneck's Avatar
arkredneck
can i soak a rag with gas and stuff it in the air cleaner inlet and take it out after it fires off?? it does have a turbo if that matters
Old Jan 26, 2009 | 06:57 PM
Vinford's Avatar
Vinford
Put a tarp over it and put some electric heaters in it.
Charge the batterys.
Once you have it charged up and warmed up a little, give it a shot of ether and it should go, if all thats stopping it from going is the cold.
Old Jan 26, 2009 | 07:03 PM
fellro86's Avatar
fellro86
I would be a bit concerned about that getting sucked in once it should fire...
Old Jan 26, 2009 | 08:39 PM
wmiller's Avatar
wmiller
lay the rag right over the filter. works great
Old Jan 26, 2009 | 08:44 PM
c00nhunterjoe
i hate things soaked in gas laying on things that can explode....... my vote still lays with a shot of ether and good batteries
Old Jan 27, 2009 | 02:20 AM
FARM69's Avatar
FARM69
Just give it a good shot of ether if she still cranks over. If not, put the hot start on her for 30 minutes and then try to get it to pop.
Old Jan 27, 2009 | 07:15 AM
Cuda_jim's Avatar
Cuda_jim
If you don't want to open up the cooling system you could get a magnetic oil pan heater and wrap the engine with anything that will hold the heat.
Engine oil pan heaters, filter heaters & battery warmers. Designed for cars, diesel engines, more effective than block heaters, magnetic heaters. Suitable for Volkswagen vw beetle, Audi, Land Rover, Ford, Chrysler, GM,
Old Jan 27, 2009 | 07:23 AM
2 stroke man's Avatar
2 stroke man
just give it a snort of ether.
Old Jan 27, 2009 | 08:43 AM
ke5chn's Avatar
ke5chn
hit it
with ether and go play in the ice. by the way where in ark are you?
Bill
DarrinPA
Sep 14, 2011 08:57 PM
swooshcmk
May 27, 2010 04:13 PM
JackDaniel
Garage & Workshop
22
May 5, 2010 07:56 PM
85Diesel_F250
General Diesel Discussion
45
Mar 29, 2009 07:58 AM
Vinford
General Automotive Discussion
Feb 26, 2009 12:14 AM
