351M rebuild kit
Old Jan 25, 2009 | 10:26 PM
fromm's Avatar
fromm
351M rebuild kit
Hi, I am looking for a rebuild kit for a 351M. Does any one know where I can purchase a good one with out breaking my wallet
Old Jan 25, 2009 | 10:58 PM
Colo79Ford's Avatar
Colo79Ford
Old Jan 25, 2009 | 11:06 PM
Colo79Ford's Avatar
Colo79Ford
Also, if you are going to buy pistons, from TMeyer, or another supplier, you can buy just a "re-ring" kit so you dont end up having a set of 8 pistons you dont want laying around.
Old Jan 26, 2009 | 01:09 AM
hollenjoe's Avatar
hollenjoe
build that thing into a 400, just need crank and pistons
Old Jan 26, 2009 | 05:45 PM
fromm's Avatar
fromm
Where can a 400 crank be purchased at. I have check summit and Jc whitney and have come up empty handed.
Old Jan 26, 2009 | 07:00 PM
JBradley500's Avatar
JBradley500
tmeyerinc.com
buy your stuff from him
Old Jan 27, 2009 | 09:00 PM
fromm's Avatar
fromm
If i was to use the cleveland heads on the 351M what intake would I have to purchase for it. The 351M intake or the Cleveland intake.
Old Jan 28, 2009 | 05:26 AM
JBradley500
351m/400 if they are the 2 barrel version of the heads which both 351m/400 and 351c used unless you have a 4 barrel 351c head.
Old Jan 28, 2009 | 07:12 AM
fromm's Avatar
fromm
If I do use 4v 351c heads will the aftermarket 351m/400 4 barrel intake work.
Old Jan 28, 2009 | 08:38 AM
JBradley500
no you will need the adapter plates from PMI. i have these that i am not using actually and a 351c performer intake that is polished since i am not using the 4v heads anymore.
Old Jan 28, 2009 | 04:27 PM
fromm's Avatar
fromm
What, or where is PMI.
Old Jan 28, 2009 | 04:29 PM
JBradley500
price motor-sports engineering inc
Old Jan 28, 2009 | 05:41 PM
fromm's Avatar
fromm
JBradley500
You said your not using the 4v heads any more. Are the 2v heads better or you using them for fuel mileage. Just curious if maybe im going in the wrong direction. Thanks for the help btw
Old Jan 28, 2009 | 07:02 PM
JBradley500
the 2v heads stock will make 325-350 hp and 450 ft lbs without much trouble. you will also need 4v headers which aren't made for a truck so you need shortys. i didn't mean to go with 4v ports but bough aussies that were ported and they were pretty much a 4v port so i had to go with the intake set up. when i found out the heads were ported into the water jacket when i put water to the engine i had to get new heads. CHI heads are about the best you can get for these with the stock port locations and i already had a 400 2v intake so i think this is the best setup i can go with.
to sum it up, 4v heads are pretty huge and need RPM to take advantage of them and stock 2v heads will do what you are looking for in most applications unless you are stupid like me and spend all of your money on a truck engine.
note-chi heads are the way to go if you have money. by time you get your 4v heads machined and put 6-700 into your 4v intake setup and machining you should just get aluminum ones that are already machined and fit stock intakes. the ports on 2v chi heads are like 23% smaller ports but at peak flow the chi flows 12% more air. also the chambers are re-engineered and the plugs are re-located.
Old Jan 28, 2009 | 07:19 PM
fromm's Avatar
fromm
Ok, I think I will stay with the 2v heads. I dont need anything over 350 hp. Plus I already have 2v heads it will be cheaper and thanks again
