water pump wooo's
Old Jan 25, 2009 | 02:31 PM
zed326's Avatar
zed326
Cool water pump wooo's
i am trying to replace the water pump on my 98 expy but i cant get the fan off the end of the pump to get at the bolts is there a trick to this? when i turn with the new belt on everythiong spins. does it turn clockwise or counter thanks
Old Jan 25, 2009 | 05:07 PM
shorebird's Avatar
shorebird
Go to a auto parts store and borrow a set of fan wrenches. The clutch unscrews by moving it opposite the direction the fan spins when the motor is running.
Old Jan 25, 2009 | 05:26 PM
zed326's Avatar
zed326
thanks thats what a friend had told me after i posted....now the dam thing still has low heat output. if you rev it up the heat gets better but not what it should be. i did the thermostat and water pump today...any ideas???
Old Jan 25, 2009 | 08:43 PM
shorebird's Avatar
shorebird
Is the fan blowing strong? If yes you may have a blend door sticking in a position that allows cold air to mix with the hot air. Has there ever been a cooling system flush done? The heater core may be clogged.
Old Jan 28, 2009 | 03:52 AM
zed326's Avatar
zed326
no when it warms up the coolant is comeing out of the fill box like it is pluged?
chermansr
Nov 1, 2013 03:22 PM
r2millers
All Things Towing
18
Jun 11, 2013 09:20 AM
1L243
24
Sep 29, 2012 09:52 AM
jconk5
Jul 16, 2005 04:11 PM
beckandyork
May 20, 2002 04:07 PM
