RSK and Superduty springs
Hey everyone, So I was looking at some albums and ran across this one...
https://www.ford-trucks.com/user_gal...?albumid=32493
Anyone ever have experience with this lift? I assume its a lift....
Looks like a reverse shackle mod that will add some lift. Placing the shackle on the rear of the front spring is better. As you can see the SD springs are longer than stock springs, suposed to help give a better ride. RSK? Reverse Shackle Kit? http://www.projectresponder.com/oru-...shackle~20.htm
Yea I see what you are saying about the SD springs but I am talking more about the RSM. Just makes sense that when the springs compress they should also be able to go back. When you hit a bump the tire is going to be forced back so the shackle should be in the back. I am about to do both, lift spring a RSM.
lol, ya i'm in WA but thanks NY is alittle far away lol . ya i ues to run 44's but the laws here are tough. So i went to stock and dually now. So I built the mt to do things and get away with it lol . Now on certen things i can run on the roads with no prob. lol . I got them . LOL . oh well now I just have to survive like every one else.
Newred, More info https://www.ford-trucks.com/forums/7...ackle-mod.html
Thanks scatgo!!!!
This is quite tempting, Ill have to compare it with a leveling kit though.
Hey Crash1, How did your truck do off road with the Reversed Shackles??
on
Certainly recommended for off road and how do you figure it won't perform as well as a lift spring? Last time I checked lift springs or not these trucks weren't hard core offroaders anyway.
RSK and SD springs will be just fine off road. Shoot you could even just use the stock springs and the RSK and get a big improvement in the ride cause the front suspension is designed as it should have been from the factory.
