injector buzz test
Old Jan 24, 2009 | 12:54 PM
steelhead2's Avatar
steelhead2
injector buzz test
did an injector buzz test again cold and #8 dont click. i'm assuming the solenoid is stuck open?. doesnt give any codes.what do you think?. it's an 04 6.o btw.
Old Jan 24, 2009 | 02:15 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
the solenoid is shot, or stuck. you might want to pull VC off just to see if maybe just maybe the plug is loose on the injector....
hope its as easy as that.
Old Jan 24, 2009 | 03:44 PM
fordmustangfan67's Avatar
fordmustangfan67
Maybe a stupid question but how do you do an injector buzz test and what all can you find out from doing this?
Old Jan 24, 2009 | 04:15 PM
silverstang's Avatar
silverstang
there isnt a plug that will come loose on the injector under the valve cover really, its possible, but highly unlikely. The plug on the 6.0 injectors pertrudes through the top half of the cylinder head (an aluminum piece bolted to the ACTUAL cylinder head).......that is the only electrical connector you are going to really see a problem with. You sir most likely have a problem with the injector itself. possibly a bad pin on a connector, near the FICM maybe, but its highly unlikely.
Old Jan 24, 2009 | 04:20 PM
silverstang
Its not considered a Buzz test on a 6.0, its an Injector Electrical Self Test, or in other terms, a "click" test. Buzz test was used on a 7.3.......its the same principal though. You do the test with a scanner or a type of diag. equipment that is capable of it. You pretty much listen for odd sounding clicks. (if one injector is WAY too quiet compared to the others, or doesnt make a noise at all, you know you have a problem).........it will also show codes sometimes if their is a problem in the injector circuitry. It seems 99% of the time I never get codes, even if injectors are bad.
Old Jan 24, 2009 | 06:01 PM
steelhead2's Avatar
steelhead2
did another click test after i ran it and they all click fine???????????still smoking like crazy too.
Old Jan 24, 2009 | 07:28 PM
brickie's Avatar
brickie
Unplug #8 and put some dielectric grease on the connection.If it still acts up buy a new injector and O rings and follow the directions in the Tech folder.IMHO
kurboman
Oct 26, 2014 08:33 PM
wackercattle
Aug 25, 2013 10:06 PM
carltonwebb
Jan 14, 2012 11:15 PM
Yougotthehit
Oct 8, 2009 07:36 PM
97 HD
Oct 23, 2007 06:24 PM
