300 exhust help
Old Feb 27, 2002 | 04:47 PM
stover007's Avatar
stover007
300 exhust help
I have a 1987 F 150 with a 300 engine can i run no muffler on it just a peice of pipe comming off the catalytic converter? Do i need more backpressure or what or is that enough back pressure? I was told that the catalytic converter doesnt work will that change anything? If i just run a peice out the back what will it do if i dont have enough back pressure?
Old Feb 27, 2002 | 08:52 PM
warriorblaze's Avatar
warriorblaze
300 exhust help
It should be fine, I put a 90 degree elbow in after my 2nd cat and a piece of pipe from it to the side of the truck ending in a chrome turndown tip. I've noticed a little more power and a lot more noise all for 20 bucks... btw its 2 1/4 inch pipe
Old Feb 27, 2002 | 08:53 PM
85351ho's Avatar
85351ho
300 exhust help
it will be fine, it wont be that loud either
Old Mar 19, 2002 | 10:32 PM
Syrnok's Avatar
Syrnok
300 exhust help
[updated:LAST EDITED ON 19-Mar-02 AT 11:33 PM (EST)]I just put a 3" flowmaster from and including the cat back to the tailpipe in the stock configuation. A little expensive but the power and milage gains were worth the cost.If you have to little backpreassure I believe that there is a tendecy to burn the valves over time. Short term thrill for long term Bill. OK inrace cars when you do the work often anyway.
93 FI50 4x4 4.9l Auto Afore mentioned exhaust, K&N, MSD Blaster coil,Hypertech Powerchip. GooD SOUND*$#@*)({[]"::'
Old Mar 21, 2002 | 01:24 AM
V10man's Avatar
V10man
300 exhust help
1990inline6
Oct 2, 2014 08:11 PM
RIKIL
Exhaust Systems
Jun 15, 2013 03:23 PM
ole-red
1997 - 2003 F150
Apr 11, 2005 05:53 PM
AuspeX
Jan 29, 2005 06:14 PM
boogity24
General Automotive Discussion
Jun 19, 2004 06:45 PM
