WOP quick spool turbo???
Old Jan 24, 2009 | 01:03 AM
strokin'_tatsch's Avatar
strokin'_tatsch
so i have been thinking a lot about turbos recently and although i probably won't be getting one too soon i'm wondering if anyone knows anything about the wide open performance quick spool turbo. i'm just kinda wondering how much air it would flow vs a stock h2e? modded h2e? just trying to dig for info sense i will be putting an after market turbo in the truck after i do stage 2's... and maybe a fuel system... thanks
Old Jan 24, 2009 | 08:07 AM
FARM69's Avatar
FARM69
I'm not familar with WOP quick spool, but in most cases the term "quick spool" is usually associated with less CFM on the high end. Unless the turbo is pretty good size to begin with, I'd stay away from quick spools running II's.
Old Jan 24, 2009 | 09:15 AM
tjbeggs's Avatar
tjbeggs
I believe the QS is based on a H2E but I am not sure. Email WOP they will give you some info to compare it to.
Old Jan 24, 2009 | 06:19 PM
foxracing0934's Avatar
foxracing0934
I think Cowboy Steve (Powerstroked???) was tossing that up against a Garrett turbo, maybe he will pipe in an share the knowledge he has gathered. I do know that it looks really nice on their site though.
Old Jan 24, 2009 | 09:00 PM
barebackjake's Avatar
barebackjake
the qssb is a modified h2e the flow is a bit less than the h2e. i would thick to the h2e for 2's but double check with zane
Old Jan 25, 2009 | 12:19 AM
strokin'_tatsch
i will check with zane on it. it looks good on the site, but it makes sense that it wouldn't flow as much up top like the H2E would. thanks guys
Old Jan 25, 2009 | 08:23 AM
barebackjake
i think it uses h2 ex housings so changing the housing may make enough air. what about a gt38r??
i gotta find me a gt4209 or hx50 for the sequentials!!
Old Jan 26, 2009 | 02:20 PM
lukecline's Avatar
lukecline
jake, the qssb is s300 based... From what ive seen it supports similar hp as the 38r drop in turbo. there's no way id pay that much for a turbo that small, when a drop in is half the price and does just as much.
Old Jan 26, 2009 | 08:49 PM
strokin'_tatsch
i'm thinking the modded h2e is going to be a better choice.. goal is now to have stage 2's and at least a stock h2e by the next dyno day!!!!!!!!!!!!!!!
Old Jan 26, 2009 | 09:07 PM
Gobstopper909's Avatar
Gobstopper909
are the hx50, 35, 55 i see on ebay from dodges? i cant find any other site that sells them, maybe im looking in the wrong spot. looking for parts to piece together
Old Jan 27, 2009 | 02:17 AM
FARM69's Avatar
FARM69
The S300 is definitely too small. I have a built s400 on the bench and its about the same as the hx50 in size before it was built.
The baby cummins comes with the 35 stock and the 40 in the HO. Your 50 is coming from the lower end M11's and older L10's. There is a pretty good jump between the 50 and 55 IMHO. The 55 is pretty common on your mid-large M11's.
Old Jan 27, 2009 | 07:18 AM
Neal 97 250's Avatar
Neal 97 250
If I may say so, the H2e and stage II's make a darn nice setup. I have the modded H2e and 6.0 cooler with beans 3" intakes. It has a bit of lag but that works well for me, cause I tow and not race. It spools at about 2000 RPM and you better be holding on when it does. Very fun truck to drive, especially with 4.10 gears.
Old Jan 27, 2009 | 09:21 PM
strokin'_tatsch
hmmm. Neal, you have 180cc sticks correct? i have 3.55 gears so how much more lag do you think i would be looking at if i went with 160's with the modded H2E with my 3.55's? oh yeah and how much did the 180's run you? i may see if Jim can make me some 180's...
Old Jan 28, 2009 | 06:04 AM
Neal 97 250
The 180's were the same price as his stage II's just machined a bit more. I don't think the gears have that much to do with the lag. You will just be at a faster speed than I am when you spool. The lag is not bad at all. I hardly notice it. Thing is that when I accelerate it goes fast and the all of a sudden WHAM I am screaming. Most time I gotta let out of it cause it will launch me a few places further up in traffic than I want to be.
Old Jan 28, 2009 | 03:05 PM
Gobstopper909
thanks for the info farm.
theres nothing wrong with that!!
