Sponsored by: Real Truck
DCSpecial....
Old Jan 23, 2009 | 07:27 PM
Sooper-Doodie's Avatar
Sooper-Doodie
DCSpecial....
I have heard you run 10.25 gears in your 10.50 housing. I am thinking about going the same route but have a question. Should the integrity of the 10.25 gears be of concern if I tow a 7000 lb trailer?
Old Jan 23, 2009 | 08:15 PM
Monsta's Avatar
Monsta
Sit. Stay.
No. I put 10.25 4.30 gears in my 05 housing. It should be of no concern.
Old Jan 23, 2009 | 08:39 PM
Sooper-Doodie
Sweet. I'm ending this 3.73 curse this weekend.
Old Jan 23, 2009 | 08:43 PM
DCSpecial's Avatar
DCSpecial
No issues as long as you get the 10.25 pinion bearing as the inner pinion bearing is taller on the 10.25 compared to the 10.5.
I didn't have any issues hooking up to a stuck 40 ton semi....
Old Jan 23, 2009 | 09:02 PM
Sooper-Doodie
Thank you.
Old Jan 23, 2009 | 09:54 PM
RACERX7775's Avatar
RACERX7775
just curious, WHY???? why not just get the gears that are supposed to be in the housing. is there a difference in price or are you getting the gears from another truck...
Old Jan 23, 2009 | 10:04 PM
DCSpecial's Avatar
DCSpecial
Because they don't make all the ratios in a 10.5" gear set.
Sometimes you only have the choice of a 10.25".
FWIW it's the exact same housing and carrier either way.......just different ring and pinion and inner pinion bearing.
Old Jan 23, 2009 | 11:17 PM
RACERX7775's Avatar
RACERX7775
oh,ok. i didnt know about it being the same housings. wish it was easy to do the 4.30's in my X. Iput a set of 5.13's in my dodge with detroit lockers front and rear and that sucked. why couldn't it be as easy as doing the ones in my mustang with the 9" in it. do everything on a bench.
Old Jan 24, 2009 | 12:16 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The axle housing is the exact same, just the ring gear diameter changed (and the pinion set up that goes with it).
IIRC most aftermarket gears are 10.25 anyway.
lil ford mec
Feb 18, 2014 01:40 AM
dazedandconfused
Dec 19, 2013 07:40 PM
pacrewchief
Dec 11, 2011 11:57 PM
Brown Falcon
49
May 29, 2011 10:43 AM
rmalottwtes30
Sep 26, 2009 06:02 PM
