some quick advice please
Old Jan 23, 2009 | 12:11 AM
Kris.'s Avatar
Kris.
hey everyone, i have a quick question on oil changes. I am about 500 miles overdue on my oil change, but i am in the middle of moving and am REALLY strapped for money. How long can i go on this oil without messing my truck up. I was going to head into my oil shop tomorrow and have them top the truck off but im just wondering if this is going to ruin my engine or not. Any advice would be helpful. Thanks a lot everyone.
-Kris
Old Jan 23, 2009 | 12:26 AM
gmm's Avatar
gmm
What is your normal change interval? Most oils will last at least two times the old change it every 3k miles saying. Most important thing is to make sure it always has enough.
Old Jan 23, 2009 | 01:11 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Don't worry about it, do it when you can, just don't run it to low. My last change got away from me and was 11,000 mile on dino (not good, I know).
Old Jan 23, 2009 | 07:40 AM
F350-6's Avatar
F350-6
What oil are you running, and how often do you normally change it? Your fuel injectors fire off of engine oil, so extended drain intervals can leak to injector issues ($300 ea) down the road.
If you're running a good quality oil, and plan on having it changed before 6000 miles, you'll probably be fine. I've had oil analysis done on several oils at the 5000 mark, and all of them could have stayed in there longer in my truck.
Old Jan 23, 2009 | 08:09 AM
Izzy351's Avatar
Izzy351
You can definitely go longer than the "normal" 5000 mile OCI as Chris stated, especially with syn oils. However, you can get 3-5qt jugs of Motorcraft 15W-40 for ~$35, and a Motorcraft filter for $10 at Wal-Mart. That's a $45 oil change -- if you're already pushing it, you might be able to pull that off.
Old Jan 23, 2009 | 09:34 AM
brian42's Avatar
brian42
Veteran: Navy
I also thought that the anti-foaming agents in the oil break down over time (which is bad for us and the high pressure oil used to fire the injectors)...?
Old Jan 23, 2009 | 10:17 AM
Kris.'s Avatar
Kris.
ok cool then it sounds like im safe. another question what is a good oil to run in our engines? my vw's i always use mobil 1.
Old Jan 23, 2009 | 10:28 AM
4inchlovin's Avatar
4inchlovin
I run Delo... But there is always everyones fav. oil.
edub32's Avatar
edub32
i just run tractor supply traveller oil 15w-40. I'm telling you this is the best oil for your money. i've heard good things about rotella also.
Old Jan 23, 2009 | 10:33 AM
87 F-150 I6's Avatar
87 F-150 I6
I run Rotella 5w40 syn, its great in the winter time and it quieted down the truck. You can get it at Wally world
Old Jan 23, 2009 | 10:37 AM
F350-6's Avatar
F350-6
Yes, but the anti-foam additive seems to hold up well as long as you stick within the 5-6k interval. Some have reported running longer with no issues, but I don't do that.
I've used Delo, Rotella, Valvoline, Mobil Delvac, all in the 15w-40 range and all have performed well. I think the TSC oil is mystic, which is owned by Hugo Chavez.
Old Jan 23, 2009 | 04:13 PM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by F350-6
Yes, but the anti-foam additive seems to hold up well as long as you stick within the 5-6k interval. Some have reported running longer with no issues, but I don't do that.performed well.
Good to know. Thanks. (sorry I can't rep ya, gotta spread it around)
I've used Rotella dino and syn and had good luck with both. I'm currently using Mobil Delvac (got a good deal on it). My truck seems to burn a little more oil with the Mobil but it also seems to be running a bit smoother. Most of the diesel oils are good as long as you make sure they have the correct rating (CJ-4 or CI-4 I can't remember which) and change it at regular intervals. I've got nothing against Shell but my rig seems to like the Mobil.
Old Jan 23, 2009 | 08:24 PM
Kris.'s Avatar
Kris.
well i ended up changing it with rotella, then i drove about 320 miles to my new place here in portland, i got great mileage and yes my truck either is a lot quieter or i just have that mindset and am convincing myself its quieter. So far i like it though. Thanks for all the help and advice from everyone!!!
kris bassett
Engine Swaps
Jul 17, 2009 02:07 PM
kickinshos
Wisconsin Chapter
May 19, 2008 02:44 PM
kris bassett
Oct 9, 2007 10:34 PM
Ksnarf
Aug 20, 2004 10:39 AM
